FI Prelude Reliablity
Old Aug 20, 2004 | 01:11 PM
JDM00SI's Avatar
Default FA Prelude Reliablity
sup,
When you boost a Prelude, do you loose reliablity?
It'smy daily driver from school/work.....cant loose reliablity.
Thanks
Old Aug 20, 2004 | 01:12 PM
JDM00SI's Avatar
Default Re: FA Prelude Reliablity (bigbeasta4)
i meant to type FI, forced induction haha
Old Aug 20, 2004 | 01:30 PM
TimeRacer's Avatar
Are you going to spend the $6-8k to build the engine, correct ECU, fuel and ignition and precautionary requirements to make it reliable?
Old Aug 20, 2004 | 01:32 PM
satan_srv's Avatar
yes you pretty much lose all reliablility, like when you can't drive your car cause you broke your ringlands
Old Aug 20, 2004 | 02:20 PM
LudeyKrus's Avatar
You throw on a charger system on a motor, there are TONS more parts to break, fail, and/or to screw things up.
Want reliability? Keep the honda n/a.
Old Aug 21, 2004 | 01:12 PM
iwhichisme's Avatar
but of course!!, the further away from stock ya go, the closer to failure you come. Of course there are exceptions to that rule. A properly built and tuned engine will certainly outlast a poorly prepaired one, and may even be as reliable as a stocker with a reasonable driver. jmo
peace,
Old Aug 21, 2004 | 05:53 PM
Kal's Avatar
Kal
Just remember the fact.
A car that was never designed to be boosted from the factory is never reliable as one that was designed for boost.
Old Aug 21, 2004 | 06:21 PM
Nikoli's Avatar
Default Re: FA Prelude Reliablity (Kal)
Confuscious say "its only as reliable as your pocket is deep"
Old Aug 21, 2004 | 10:20 PM
sharkcohen's Avatar
Default Re: FA Prelude Reliablity (Deckedlude)
Going on two years now with my blower, ran 9 psi for over a year.
Old Aug 22, 2004 | 07:07 AM
01 LudeDude's Avatar
Default Re: FA Prelude Reliablity (sharkcohen)
for another JRSC daily driver
Old Aug 22, 2004 | 07:25 AM
fastludeh22's Avatar
Default Re: FA Prelude Reliablity (01 LudeDude)
its all about fuel mgmt. and its not cheap. if u keep the engine stock, get like hondata, and run ~8 psi it should last awhile. it will never last as long as fully stock, but if taken care of should last long enough for you to want to build it and turn up the boost.
a little old school for ya,
pick 2:
cheap, fast, reliable
Old Aug 22, 2004 | 08:18 AM
ludermark's Avatar
Default Re: FA Prelude Reliablity (fastludeh22)
a honda on boost will last longer if you baby it, not drive around like a dipshit hitting max boost everywhere you go . Save letting it go for the track, or for the rich guy next to you at a red light with an m3
Old Aug 22, 2004 | 10:40 AM
sharkcohen's Avatar
Default Re: FA Prelude Reliablity (ludermark)
I drive mine hard every single day.
Old Aug 22, 2004 | 02:27 PM
Mario.'s Avatar
IMO, invest $200 in Uberdata supplies is totally worth it if you are looking for reliability.
Likewise said... moderation is key i.e. your right foot.
Old Aug 22, 2004 | 04:02 PM
connvict's Avatar
fast is not reliable, but reliable is not fast........
Old Aug 22, 2004 | 06:17 PM
ludetech
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbeasta4 &raquo;</TD></TR><TR><TD CLASS="quote">sup,
Thanks</TD></TR></TABLE>
Read and do some more reading when your done with that. find out all about these things
tuning
engine managment systems
fuel setups
injectors
pumps
fmu's (fuel management units) fpr's (fuel pressure regulators)
fuel rails
all the components of a turbo system
how a wastegate works
how a turbo works
how a bov works
how air fuel works
ratios
ideal ratios
timing retard
what a wideband is and how it works
figure out how to read a turbo compressor map and read efficiency so you can determine for yourself what turbo is ideal for your desires
figure out how to run all your lines vacum/oil feed and drain
information about your current motor
what its capable of
what its compression is
what boost its good to
have it compression tested
read fi forums alot and read what kind of problems people are having and what there solutions where
this is not a yes or no question. If you are asking this question you dont know enough to be turboing your car and keep it running reliable. the most unreliable turbo setup is the one where the owner does know what he's doing
k20powered
Mar 10, 2010 07:08 AM
Ms.Prelude
Oct 18, 2007 07:54 AM
8399_hn
Jan 16, 2006 03:59 AM
rluder21
Nov 8, 2002 08:54 PM
Not Me
Nov 2, 2001 03:04 PM
