coilovers?
Old Aug 20, 2004 | 11:42 AM
alex01's Avatar
Default coilovers?
i just installed some coilovers on my 2001 accord. After the install i drove and noticed that my car tends to go to the right. Do i have to have an alignment done again becuase of the coilovers or is it that the the left and right springs are dropped at different measurements? Thanks.
Old Aug 20, 2004 | 12:30 PM
Nick H's Avatar
New User
Default Re: coilovers? (alex01)
well, you should technically get your car corner weight balanced with coilovers, but if you don't want to pay for it, just adjust all 4 corners to the same height and be done with it...
also, yes you need to get an allignment after installing new suspension pieces...good luck
Old Aug 20, 2004 | 12:32 PM
.bagged's Avatar
Default Re: coilovers? (Nick H)
Yup, make sure your car is level (ie what nick said) and then get an alignment.
Old Aug 21, 2004 | 12:47 PM
aZnAcCoRd02's Avatar
Default Re: coilovers? (bagged93accord)
yeah mos def get an alignment
your car might lean to one side like mine does because the motor offset puts most of the weight on a certain side....just adjust to make it hte same height
Old Aug 21, 2004 | 02:07 PM
azian21485's Avatar
Default Re: coilovers? (aZnAcCoRd02)
your toe is thrown way off when raising or lowering your vehicle..adjust the car's height to where you want it and then bring to an allignment shop
Old Aug 23, 2004 | 12:12 PM
alex01's Avatar
thanx everyone... this stuff is helpful!
dc2long
Apr 23, 2007 11:47 PM
DIP_SET FoReVr
May 13, 2004 12:08 PM
asylum
Apr 8, 2004 06:28 AM
EL'ation
Sep 28, 2002 01:11 PM
