What is the correct offset and lug-nut distance for a 17inch rim on a 92 civic HB??
Old Dec 3, 2001 | 05:38 AM
JD_B18CDX's Avatar
Default What is the correct offset and lug-nut distance for a 17inch rim on a 92 civic HB??
Do you have to roll the fender lip for the rims to clear??
Thanks!
Old Dec 3, 2001 | 06:17 AM
jgale's Avatar
Default Re: What is the correct offset and lug-nut distance for a 17inch rim on a 92 civic HB?? (johnd)
I have a '94 hatch w/ 17x7 w/ a 40 offset and 205/40 17 BFG drag radials. It's lowered quite a bit(2" maybe). If I set the camber to anything less than 1.5 degrees it rubs when turning and hitting a good bump(my driveway). With where the camber is now(1.8-1.9 degrees neg.) it hasn't hit-yet. Although i'm pretty careful w/ it. If you have a decent amout of camber and and a 7" wide wheel w/ at least a 42- 45 offset, you should be fine. Anyone agree?
Old Dec 3, 2001 | 11:32 AM
JD_B18CDX's Avatar
Default Re: What is the correct offset and lug-nut distance for a 17inch rim on a 92 civic HB?? (jgale)
Thanks!
Do u have a pic of your car?
Old Dec 3, 2001 | 12:52 PM
jgale's Avatar
here's some older ones. I'm working on getting more developed... http://briefcase.yahoo.com/bc/dzd3v5...c=bc%26.view=l
[Modified by jgale, 5:18 PM 12/3/2001]
420_EM1
Oct 9, 2013 05:43 PM
epraion62
Aug 17, 2005 02:08 PM
2000si
10
Nov 21, 2003 03:42 PM
Diabolik
Mar 15, 2003 06:53 AM
ruiner17
Apr 3, 2002 11:00 PM
