itr gauge cluster question.. need answer QUICK!
Old Aug 20, 2004 | 10:55 AM
SHystrdyGSRtdy's Avatar
Default itr gauge cluster question.. need answer QUICK!
this is a 96 cluster correct?
will it fit a 95 integra?
if a larger picture is needed add ".orig.jpg" into the url of the picture.
Old Aug 20, 2004 | 10:57 AM
Inspector Gadget's Avatar
Default Re: itr gauge cluster question.. need answer QUICK! (SHystrdyGSRtdy)
I believe it would. Anyone feel free to correct me if im wrong.
Old Aug 20, 2004 | 11:15 AM
Haleiwa-Brando's Avatar
Default Re: itr gauge cluster question.. need answer QUICK! (Shit_Bam)
All 94 to 01 gauge clusters are compatable with one another...being that you are swaping a manual trans gauge cluster, for manual trans gauge cluster.....auto trans gauge cluster for auto trans gauge cluster. That's a nice little JDM one that you got there. What did you pay for it?
Hope this helped you.
Old Aug 20, 2004 | 12:00 PM
Default Re: itr gauge cluster question.. need answer QUICK! (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">All 94 to 01 gauge clusters are compatable with one another...being that you are swaping a manual trans gauge cluster, for manual trans gauge cluster.....auto trans gauge cluster for auto trans gauge cluster. That's a nice little JDM one that you got there. What did you pay for it?
Hope this helped you. </TD></TR></TABLE>
sorry but you are wrong.. because the 96 gauge cluster i have does not work on my 99 gsr... the fuel does not work... i tried on a 96 integra and it worked... now i need to know does it work on a 95... thanks for trying to help though
Old Aug 20, 2004 | 03:07 PM
Seedc2's Avatar
I believe that the 96' spec itr clusters work on all 94-97 USDM integras. And 98 spec itr clusters should plug and play with all 98+ USDM integras.
In the case it doesnt just swap the motherboards out and it should work perfectly.
Old Aug 20, 2004 | 03:42 PM
B_CRUZ!'s Avatar
you have to transfer the green wire sheet from your OEM one to your JDM one.
Old Aug 20, 2004 | 07:14 PM
Default Re: (b cruz)
anyone know what color it lights up?
thanks for the help guys!
Old Aug 20, 2004 | 08:42 PM
Mr.DC2's Avatar
if you have the icon that represents the cataylic converter overheating, then you have the 96 spec which will work on all 94-97 tegs. this icon is located in the upper left corner where your check engine light is located.
it lights up amber. exactly the same as my avatar.
Old Aug 20, 2004 | 11:36 PM
uNF$@#!'s Avatar
Default Re: (Mr.DC2)
that cluster is from a 2007 RSX. it wont fit in any integra. better sell it....
i'll pay $20 shipped for it.
let me know.
Old Aug 20, 2004 | 11:53 PM
esponet's Avatar
97-97R cluster will work on 94-97 tegs, 98+ONLY ON 98+ tegs without modifications
yes that is a 96,7 cluster
Old Aug 21, 2004 | 02:39 AM
Default Re: (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">that cluster is from a 2007 RSX. it wont fit in any integra. better sell it....
let me know.</TD></TR></TABLE>
nice try
Old Aug 21, 2004 | 09:05 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2 &raquo;</TD></TR><TR><TD CLASS="quote">if you have the icon that represents the cataylic converter overheating, then you have the 96 spec which will work on all 94-97 tegs. this icon is located in the upper left corner where your check engine light is located.
it lights up amber. exactly the same as my avatar.</TD></TR></TABLE>
correct.
Old Aug 21, 2004 | 08:27 PM
SYTFU Tommy.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">this is a 96 cluster correct?
wat does the ( () ) looking thing mean?
Old Aug 21, 2004 | 08:35 PM
Seedc2's Avatar
Default Re: itr gauge cluster question.. need answer QUICK! (tngay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay &raquo;</TD></TR><TR><TD CLASS="quote">
wat does the ( () ) looking thing mean?</TD></TR></TABLE>
E-Brake
Old Aug 21, 2004 | 10:29 PM
Default Re: itr gauge cluster question.. need answer QUICK! (kendogg)
are you sure? i thought that was the cat. icon?
Old Aug 21, 2004 | 10:37 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">are you sure? i thought that was the cat. icon?</TD></TR></TABLE>
yes he is correct it is the brake light. i know for sure because i have the working gauge in my car... and the gauge is a 98+ version
Old Aug 21, 2004 | 11:07 PM
Default Re: itr gauge cluster question.. need answer QUICK! (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">
yes he is correct it is the brake light. i know for sure because i have the working gauge in my car... and the gauge is a 98+ version</TD></TR></TABLE>
what gauge is a 98+ version? mine?
Old Aug 21, 2004 | 11:10 PM
cxSHOE's Avatar
not sure we still need a clearer photo of the signs above the coolent gauge??? if you see 3 insignias above it then you have a 96 if you only see two (with nothing in the middle) then you have a 98+ gauge... as we have said in the above posts
Old Aug 21, 2004 | 11:12 PM
i tried the cluster on a 96.. it works
i tried the cluster on my 99.. fuel does not work
and what this guy is talking about:
https://honda-tech.com/zerothread?id=948386
he is wrong?
Old Aug 21, 2004 | 11:19 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">i tried the cluster on a 96.. it works
he is wrong?</TD></TR></TABLE>
what are you talking about the guy is correct on his first post??
For the 96 spec clusters, they had the Cat Heatup Warning Icon and the 98 specs didn't. The green film in the back is also quite different. Just FYI for people who don't know.
am i missing something? or are you not even reading what im telling you and what everyone above me is telling you????
and you can get the fuel gauge to work you just have to find the correct fuel gauge wires... remember the green films are different from 96 and 98+ specs.
Old Aug 21, 2004 | 11:28 PM
i understand what you are saying......
i'm telling you i have the 96 version.
and i'm telling you that i thought the (O) was the cat. heat icon... refering to this post:
Old Aug 22, 2004 | 07:24 AM
esponet's Avatar
if you lookcloseyou could makeout the over heating cat sensor.
Old Aug 22, 2004 | 07:39 AM
Mr.DC2's Avatar
Default Re: (esponet)
haha i am not gonna dive my nose into the screen to see if the cat icon is there or not. its too dark to see on this monitor.
(O) is e-brake
thats the cat overheating. yes its a HORRIBLE representation but thats close to what it looks like.
thats my cluster. e-brake light is on and the cat icon is in the top left corner in the middle. if your cluster has that icon, you have the 96 spec.
96 spec will fit all 94-97 integras
98 spec will fit all 98-01 integras
if you have the wrong cluster, and it sounds like you do, you can just swap the green film on the back between your own cluster and the jdm itr cluster.
its that simple!
Old Aug 22, 2004 | 10:22 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">i understand what you are saying......
https://honda-tech.com/zerothread?id=948386</TD></TR></TABLE>
oh ok, because you made no indication in the post saying you now know what type of gauge you had? hence all the same replies by me and others.. great this thread is done..
csykim
Dec 19, 2005 06:21 PM
c_buz
Jun 21, 2004 06:15 AM
