odd problem with si cluster
Old Aug 20, 2004 | 09:21 AM
hatchinprogress's Avatar
Default odd problem with si cluster
i have a dx that i just put in an si cluster, and my problem is when i get on the freeway and use my turn signal the rpms and the water temp the needles go up and down( just the needles not the actual motor rpms) and when i turn the signal off it stops. this only seems to happen when im on the freeway (so i think it has somethin to do with the speed) i've had a si cluster in the car befor and this problem never happend. and please dont be a smart *** and say dont use my turn signal thanks
Old Aug 20, 2004 | 09:27 AM
Fleas_Ef's Avatar
Default Re: odd problem with si cluster (hatchinprogress)
it doesnt seem to be anything to serious curious myself so bump...my 2 cents- wiring?
Old Aug 20, 2004 | 09:34 AM
YumVTEC's Avatar
check your grounds if you re-wired anything. if not, then clean the contacts on the back of the cluster. something isn't grounding right.
Old Aug 20, 2004 | 10:45 AM
Malgerus's Avatar
Default Re: odd problem with si cluster (YumVTEC)
Yup, betting on grounds as well
Old Aug 20, 2004 | 11:32 AM
Default Re: odd problem with si cluster (Mr. S)
thanks guys
Old Aug 20, 2004 | 01:50 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
use hand signals instead
but bring it by this weekend halla at me
BIGef
Jan 27, 2012 12:06 PM
kaboomwoom
Mar 12, 2008 01:06 AM
court
May 19, 2006 11:35 AM
