Swapping a b18c1 or b18c5 into a 00 ek engine bay. what engine/tranny mounts do i use?
Old Dec 3, 2001 | 12:40 AM
Tyson Ballou's Avatar
Default Swapping a b18c1 or b18c5 into a 00 ek engine bay. what engine/tranny mounts do i use?
when swapping a b18c engine into a ek 2000 civic, ( dx ) can i reuse my existing engine mounts and tranny mounts. or do i use the ones from the b18c engine? I was even told that i needed to buy mounts off a 00 si? Thanks for the help.
Old Dec 3, 2001 | 04:30 AM
C-speed's Avatar
Default Re: Swapping a b18c1 or b18c5 into a 00 ek engine bay. what engine/tranny mounts do i use? (Martin D
use all the B18C mounts.
Old Dec 3, 2001 | 12:01 PM
bfast's Avatar
the mounts you need are:99-00 civic si rear "L" bracket and lh upper block bracket
with the civic mount.the other mounts you wil use integra.be sure the engine is 96 and newer for the crank sensor.also the only ecu that is a direct plug and play is
00-01.
Suare
Feb 13, 2012 06:03 PM
sixtodc2
Jul 13, 2007 12:43 PM
stevescivic
Jan 10, 2005 09:16 PM
infamousALLMTR
Mar 5, 2002 10:24 AM
808State
Nov 9, 2001 05:26 AM
