My old H22 Head
Well i was bored....here is a shot of my old H22 head about a year ago when my H22 engine blew..... Problem: it overheated a couple of times and boost spike
Can anyone here fix it for cheap
If not cracked anywhere else, you can have that chunk welded up and the head milled, should be fine. Not sure a machine shop can pressure check until that chunk is repaired, so you might get a few dollars into it before you find out the head is junk... worth the risk, IMO.
Entheogen
Engine Machining & Assembly
Sep 22, 2015 02:35 PM
