What tranny oil do you all motor guys running 11's and 12's use?
Old Aug 20, 2004 | 03:42 AM
Ek29JDM's Avatar
Default What tranny oil do you all motor guys running 11's and 12's use?
Just like the topic says.
Would like to know what you guys found that works best for going that fast.
Thanks
Old Aug 20, 2004 | 03:44 AM
CRITTERMATT's Avatar
Default Re: What tranny oil do you all motor guys running 11's and 12's use? (Ek29JDM)
I din't know they make different fluids for different speeds. Tires yes but fluids no. I would think Honda Transmission Fluid or GM Synchromesh should work just fine.
Old Aug 20, 2004 | 03:48 AM
Tbone's Avatar
I run Kaaz for my diff. Kinda expensive.
Old Aug 20, 2004 | 04:12 AM
b19coupe's Avatar
Honda MTF.
Old Aug 20, 2004 | 04:28 AM
Bisimoto's Avatar
Default Re: What tranny oil do you all motor guys running 11's and 12's use? (b19coupe)
Torco MTF: http://www.torcousa.com
Old Aug 20, 2004 | 06:02 PM
Ek29JDM's Avatar
Default Re: What tranny oil do you all motor guys running 11's and 12's use? (CRITTERMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT &raquo;</TD></TR><TR><TD CLASS="quote">I din't know they make different fluids for different speeds. Tires yes but fluids no. I would think Honda Transmission Fluid or GM Synchromesh should work just fine.</TD></TR></TABLE>
I know they don't make different fluids for different speeds.
You missed the point.
A car going 11 or 12 is gonna stress the tranny more than someone running 14 or 15, which is why I ask for what the racers are using to help save syncros and maybe be more efficient.
Old Aug 20, 2004 | 07:42 PM
Twenty36_1's Avatar
subscribed to topic.
Old Aug 21, 2004 | 04:04 PM
HONDABROMANDUDE's Avatar
Default Re: What tranny oil do you all motor guys running 11's and 12's use? (Twenty36_1)
You know you can subscribe without replying right?
Old Aug 21, 2004 | 04:06 PM
Twenty36_1's Avatar
Default Re: What tranny oil do you all motor guys running 11's and 12's use? (HONDABROMANDUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABROMANDUDE &raquo;</TD></TR><TR><TD CLASS="quote">You know you can subscribe without replying right?</TD></TR></TABLE>
really? How do I do that. Sorry, still a newbie.
Old Aug 21, 2004 | 04:11 PM
dohcbag's Avatar
Mobil 1 racing tranny oil its the best for dogboxes but if your helical cut your not going to be putting much stress on the gears unless your clutchlesss shifting all the time
helical cut - honda fluid
dogboxes - mobil 1 racing tranny fluid
Old Aug 21, 2004 | 04:50 PM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek29JDM &raquo;</TD></TR><TR><TD CLASS="quote">
A car going 11 or 12 is gonna stress the tranny more than someone running 14 or 15, which is why I ask for what the racers are using to help save syncros and maybe be more efficient.</TD></TR></TABLE>
Yep, PM Rocket, he's got some stuff that you didn't think was available
Old Aug 21, 2004 | 04:51 PM
Ryan C's Avatar
Default Re: What tranny oil do you all motor guys running 11's and 12's use? (juanpwnz)
i dont runs 11s but my tranny gets regular 10w-30
Old Aug 21, 2004 | 05:11 PM
H22A-AllMotor's Avatar
Default Re: What tranny oil do you all motor guys running 11's and 12's use? (Ryan C)
If you're killing syncros while running 11's and 12's then you should quit racing, drag, or w/e it is that you do, or just learn how to shift properly.
Old Aug 21, 2004 | 05:55 PM
Combustion Contraption's Avatar
I use redline MTL
Old Aug 22, 2004 | 10:13 AM
krazie1's Avatar
BANNED
Default Re: (LsVtec92Hatch)
Motul 90PA fluid
it is the best I could get for my LSD....
Old Aug 22, 2004 | 11:08 AM
indomotor's Avatar
Default Re: (krazie1)
Valvoline Durablend 10-30W
Old Aug 22, 2004 | 01:22 PM
rodimus's Avatar
Default Re: (indomotor)
next i am trying castrol gtx 30 or 40 weight with redline friction modifier.
Old Aug 22, 2004 | 04:14 PM
1 2 NV's Avatar
Default Re: (EVOL)
castrol 5-30 both motor and tranny.
Old Aug 22, 2004 | 04:18 PM
atc5's Avatar
chevron 10w30 in my itr tranny
Old Aug 22, 2004 | 04:56 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (atc5)
Like Bert said Rocket has stuff that is supposed to be amazing. It is some sort of "secret mix" of different stuff.
You will have to email him though, since he doesn't plan on comming on H-T much anymore.
TomTread
May 18, 2008 05:35 PM
1JDMDOMINICAN
Sep 23, 2005 12:38 PM
mika
19
Oct 4, 2004 12:45 PM
HavokB18
20
May 29, 2003 04:16 PM
rybred
Nov 19, 2002 02:40 PM
