h22 head high compression head gasket
Old Aug 20, 2004 | 01:49 AM
b16t4turbo's Avatar
Default h22 head high compression head gasket
i searched this on this site and other sites and even yahoo.
my question is are there any company out there that offers a single layer head gasket or a thinner head gasket for an h22. i was going to get some type s pistons put in my block and i wanted to raise the comp up some more. i know that if i want to put after market pistons in it then i have to sleeve my block but i was wondering if there is a cheaper way besides milling the head.
any info is greatly appraised. thank you.
Old Aug 20, 2004 | 08:28 AM
PirateMcFred's Avatar
Default Re: h22 head high compression head gasket (b16t4turbo)
milling the head is the same as getting a thinner HG. cheaper too. $50 to mill and $50 for an OEM HG. $.02
Pirate
Old Aug 20, 2004 | 09:14 AM
ranta18's Avatar
Default Re: h22 head high compression head gasket (PirateMcFred)
3 ways... deck the block, mill the head, or get a thinner head gasket. Once you deck the block or mill the head, there is no going back. Everytime you take the head off you have to buy a new head gasket. How much more is the thinner one? Its up to you what you want to do.
Old Aug 20, 2004 | 03:08 PM
b16t4turbo's Avatar
Default Re: h22 head high compression head gasket (ranta18)
yeah i know those ways already but i was wondering if a company makes them (the head gasket). like the single layer head gasket for b-series from mugen and stuff like that. thanks for the info pirate and ranta18.
Old Aug 20, 2004 | 03:22 PM
se93's Avatar
Check with Cometic. They make different sized head gaskets.
Old Aug 20, 2004 | 07:58 PM
Pat McGroin's Avatar
Default Re: h22 head high compression head gasket (se93)
Go to http://www.Prospeedpower.com
They make custom headgaskets and make them for h22's. Click on Custom Headgaskets in the menu on the left hand side.
Old Aug 21, 2004 | 01:50 AM
jdmh22eg's Avatar
doesn't spoon make emmm?
Old Aug 21, 2004 | 12:56 PM
Default Re: (jdmctreg93)
Not for the H-series, they barely make parts for the Prelude, I have only heard of like two parts for the Prelude.
Old Aug 22, 2004 | 01:22 PM
b16t4turbo's Avatar
Default Re: (Pat McGroin)
all those companies you mention doesnt make a single or two layer head gasket. all they make are custom bore ones. maybe ill just call to talk to them. thank you any ways. if any one has any more info, please let me know.
Old Aug 23, 2004 | 07:50 AM
Default Re: (b16t4turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16t4turbo &raquo;</TD></TR><TR><TD CLASS="quote">all those companies you mention doesnt make a single or two layer head gasket. all they make are custom bore ones. maybe ill just call to talk to them. thank you any ways. if any one has any more info, please let me know.</TD></TR></TABLE>
"We have custom headgaskets available for your B, D, and H series Honda motors. They range in bore size from 81mm to 87mm for B series engines, and 87mm to 90mm for H series engines. Available in custom thickness for raising and lowering compression. They are a 3 layer metallic gasket produced to OEM quality. Please contact for any questions regarding application needs."
That is what it says on Prospeed's website.
Old Aug 27, 2004 | 03:29 PM
b16t4turbo's Avatar
my fault i just read it wrong. thanks all for the help. once again h-t has came to the rescue. thanks all.
Old Sep 20, 2004 | 07:33 PM
MUGEN_CF4's Avatar
Default Re: (jdmh22eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22eg &raquo;</TD></TR><TR><TD CLASS="quote">doesn't spoon make emmm?</TD></TR></TABLE>
Yes, but they are now discontinued; and are hard to find.
Old Feb 12, 2006 | 11:37 AM
Shaun's Avatar
Default Re: h22 head high compression head gasket (Pat McGroin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat McGroin &raquo;</TD></TR><TR><TD CLASS="quote">Go to http://www.Prospeedpower.com
They make custom headgaskets and make them for h22's. Click on Custom Headgaskets in the menu on the left hand side.</TD></TR></TABLE>
im going to give them a call.. and ask a few questions
Old Mar 21, 2006 | 09:27 PM
SASi's Avatar
Default Re: h22 head high compression head gasket (Shaun)
What did you find out about it? How much does is bump up the compression on the H22? Is it a .3 bump up?
Modified by SASi at 2:35 AM 3/23/2006
Old Mar 22, 2006 | 08:59 AM
thedread's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat McGroin &raquo;</TD></TR><TR><TD CLASS="quote">Not for the H-series, they barely make parts for the Prelude, I have only heard of like two parts for the Prelude.</TD></TR></TABLE>
Incorrect, Spoon made a high compression head gasket for the H22. It might be discontinued, but some vendors still have them. I'm sure that Spoon made them because I have one.
Old Apr 2, 2006 | 08:37 PM
SASi's Avatar
Default Re: h22 head high compression head gasket (SASi)
so who has one...and where did you guys get it?
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
-Darren-
Jun 2, 2009 03:54 PM
NSfit
Sep 20, 2006 06:43 PM
b18prl
Mar 4, 2003 11:17 PM
SPOON_BeIgHtEeNsEe
Jul 7, 2002 01:37 PM
