My lsvtec setup, help needed
Okay well i've decided to go the lsvtec route. Here is my setup, please make any comments that i might benifit off of. This setup will go into a 4 door but i am thinking about dropping it into an EF or CRX. Here goes...
Block:
B18A Block (stock bore)
PR3 Pistons
GSR Rods
ARP Rod Bolts
Competition Engineering Dowel Pins
New Seals, Gaskets, Bearings, etc
Toda Oil Pump
Toda 1 Layer Headgasket
GSR Crank
Head:
GSR (no milling)
Ferrea Valves, Valve Springs, and Retainers
ARP Headstuds
3 Angle Valvejob
Toda Spec B Camshafts
Toda Timing Belt
Slight P&P
Skunk 2 IM
GSR TB
JDM DC 4-1 Header
Fuel Managment:
Hondata S200 w/P28
AEM Fuel Rail
B&M FPR + Gauge
RC 310 Injectors
Now after all that being said my goal is 200+ whp tuned. I'm not so worried about my fuel management or my head build up but more worried about the foundation, the block. I was wondering if anybody could throw me some help and tell me if i am missing anything or could suggest something better. The motor would be daily driven also.
This is my first lsvtec setup so i'm just double and triple checking things before i really get into things. Thanks in advance.
Joe
Block:
PR3 Pistons
GSR Rods
ARP Rod Bolts
Toda Oil Pump
GSR Crank
Head:
GSR (no milling)
ARP Headstuds
3 Angle Valvejob
Toda Timing Belt
Slight P&P
Skunk 2 IM
GSR TB
JDM DC 4-1 Header
Fuel Managment:
Hondata S200 w/P28
AEM Fuel Rail
B&M FPR + Gauge
RC 310 Injectors
Joe
Everything looks good but I don't see an LS/Vtec , I see a GSR engine, since you have both crank and rods from one. Anyway with a good tune you might accomplish your goal, as you have some nice tuning flexibility.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickhatch »</TD></TR><TR><TD CLASS="quote">Everything looks good but I don't see an LS/Vtec , I see a GSR engine, since you have both crank and rods from one. Anyway with a good tune you might accomplish your goal, as you have some nice tuning flexibility.</TD></TR></TABLE>
was just about to say the same thing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkid »</TD></TR><TR><TD CLASS="quote">any comments? i just need some reassurance</TD></TR></TABLE>
use the ls rods and crank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">use the ls rods and crank.
any reason to support your answer?
</TD></TR></TABLE>any reason to support your answer?
the only reason why i decided to go with the gsr crank and rods is to be able to rev up the motor higher so my cams could benifit from it.
i don't really think an ls crank and rods can handle daily abuse to 9k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">If youre gonna do all that, just buy a GSR motor and spend the extra $$$ on nice cams a good tune.</TD></TR></TABLE>
so whats wrong with my setup then?
THe LS motor has a different rod/stroke ratio to allow more torque down low. thats why people did it. that is why wosmeone said man i wish this b16 behaived like an LS motor.
And gsr owners though, man i wish this b18c1 behaived like that LS integra next to me... under 5000.
You are getting nothing out of that block but trouble building your gsr motor. Man there is so ******* much on this forum about LS vtecs and the like. Try the hybred forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkid »</TD></TR><TR><TD CLASS="quote">the only reason why i decided to go with the gsr crank and rods is to be able to rev up the motor higher so my cams could benifit from it.
well......if you used the ls crank and rods you'd obviously have more displacement resulting in more power. revving to 9K is a waste if an ls/v is going to make more tq and hp, but, at a lower shift point. just because our motors have vtec doesn't mean that we should overrev the motor. lastly, shant on here has a 9500rpm shift point on his ls/v. he had stock rods and pr3's. i believe he had arp rod bolts, but that was it (other than the obviously r/a balancing). don't get it twisted. g/l, either way.
</TD></TR></TABLE>well......if you used the ls crank and rods you'd obviously have more displacement resulting in more power. revving to 9K is a waste if an ls/v is going to make more tq and hp, but, at a lower shift point. just because our motors have vtec doesn't mean that we should overrev the motor. lastly, shant on here has a 9500rpm shift point on his ls/v. he had stock rods and pr3's. i believe he had arp rod bolts, but that was it (other than the obviously r/a balancing). don't get it twisted. g/l, either way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkid »</TD></TR><TR><TD CLASS="quote">so basically i can rev to 9k daily on ls rods with arp rod bolts and the ls crank safely? because if i can, i would go that route instead of the gsr crank and rods...</TD></TR></TABLE>
a lsvtec is with a ls crank and rods to have the more displacement
you basically building a gsr motor in a ls block plus you wont have the squirters and girdle like a gsr
just use the ls crank you will be much better off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">8500 would be safer. i only take my LSV to 8k.</TD></TR></TABLE>
thanks lsvtec92hatch
