a couple of questions for 5gen owners.
just recently i went to start my car, then turned it off while it was still a little bit cold. The engine still kept on for about 30 seconds after i took the key out of the ignition. It sounded like it was trying to start back up or something..anywhere ever have this happen and if so whats wrong
?? Also this may sound a little basic but when i push my foot down on the clutch, it makes a little squeel. could this be telling me i need to flush my clutch fluid or something? thanks in advance
Modified by cdn_cd5 at 11:30 PM 8/19/2004
?? Also this may sound a little basic but when i push my foot down on the clutch, it makes a little squeel. could this be telling me i need to flush my clutch fluid or something? thanks in advanceModified by cdn_cd5 at 11:30 PM 8/19/2004
It sounds like you have "run-on" i have never seen that happen on a honda before.
The squeel just means you have to lube the springs/joints in the clutch pedal area.
about the squeal if it's in the engine compartment my guess would be yor slave cylinder which is located on the transmission in between your radiator fan and your trans. as far as your car still running that could be timming.
condor22
Feb 9, 2019 08:58 PM
josephemorgan91
Honda Civic (2001 - 2005)
Jan 6, 2016 09:12 PM
