RED LINE
Questions is a little vague, are you referring to the revlimiter/fuel cutoff of your engine, or the instrument gauge tach showing where your redline begins?
The d16a6(Si) motor has a redline of 7100rpm, with fuel cutoff being around there. Fuel cutoff is controlled by the ECU.
If the motor is strong, its probably okay to hit redline every now and then without having any problems, but does it still makes viable power up to 7100rpm?
racedoutsi
Mar 31, 2002 06:41 PM
