87 CRX - bolt-in swaps?
Screw you guys, I'm... going... home.
It depends on what country you're in, so first please add your "Location" to your profile and we can give you better advice. It also depends on if your CRX is carbed or fuel injected. If you're carbed then you will need to either do an mpfi swap, or convert the swapped engine to carbs. If you're in the US the easiest bolt-in swap is a D16A1 engine from an 86-87 integra. You only need to slightly modify one engine mount (hacksaw a chunk out of it) and run a couple of wires. You will also need the teg tranny/axles/hubs/knuckles/front suspension/ecu etc. The D16A1 from an 88-89 integra will bolt in the same but it requires more wiring because it is electronic advance ignition instead of vacuum advance ignition like the 86-87 teg & 87 CRX. The best place for info on 1g CRXs/3g Civics is http://www.redpepperracing.com , but PLEASE search and read the FAQ thoroughly before you start asking questions.
fenix4o9
May 16, 2007 08:29 PM
Jester88Si
40
Jul 27, 2004 11:22 AM
