2000 GSR Bucket Seats into 98 EK?
I am looking at installing a pair of GSR Bucket seats into my 98 hatch. Are they a direct bolt in, or do the rails need to be swapped or? I tried searching and couldn't come up with much. Anyone have any pics or how to's on this??
there's been alot of posts about this, but i'll be nice and give you a link
http://www.geocities.com/Motor....html
search!!!
seriously, this is covered every single week.
anyway...
3 of the holes line up.
swap your inside ek rail with the teg one. this keeps your seat belt buckle the same and also uses the vertical inside rear seat bolt - the one that is designed to withstand the most force. read=safer.
you'll have the inside ek rails and outside teg rails on the seat.
you're done.
anyway...
you're done.
swapping the rails only took like 10-15 mins per seat. I dislike the 3 hole idea because your seat can still wiggle. Better safe than sorry.
great link for the DIY too. That's the link I used when I switched my stockers to del sols.
u need to swap the inner railing " the one with the seatbelt latch", if you want all 4 bolts screwed unless if you careless you can just live the raillings as it is but the inner rear bolt for the railing will not be bolted on because the railing is about an inch short
Mr Fatty
Jul 12, 2010 11:20 AM
o0ohaviko0o
Dec 12, 2007 08:26 AM
