for a SKUNK 2 INTAKE MANI SWAP.. do i need..
Old Aug 19, 2004 | 12:44 PM
CrazyHB's Avatar
Default for a SKUNK 2 INTAKE MANI SWAP.. do i need..
for a SKUNK 2 INTAKE MANI SWAP.. do i need both the ITR cable bracket and the cable ?? or can i use my stock gsr throttle body cable??
Old Aug 19, 2004 | 12:56 PM
Marauder's Avatar
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (CrazyHB)
On what engine?
They make manifolds for D, B, and H series engines.
Old Aug 19, 2004 | 12:58 PM
CrazyHB's Avatar
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (Marauder)
gsr
Old Aug 19, 2004 | 01:05 PM
Marauder's Avatar
Well, can't help you there, that's one I haven't done.
Old Aug 19, 2004 | 01:10 PM
CrazyHB's Avatar
lol okk great anyone that has done the gsr skunk2 intake mani swap?? come unn..
Old Aug 19, 2004 | 01:21 PM
vtec94civic's Avatar
well the mounting points of the bracket on the gsr and b16 mani look the same so i think that you would need the type r bracket and cable. if you look at it they are both on the 3rd runner from the left and they are both above the iat sensor. i got mine off of inlinefour for like $35 for both. btw i have a s2 mani on a sir2.
Phantastic's Avatar
i have a ls with a skunk manifold on it and i just use the stock throttle cable and made my own bracket to hold the cable i don't think u'll need the itr stuff. it's just more of a hassle and money
Old Aug 19, 2004 | 01:54 PM
CrazyHB's Avatar
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (Phantastic)
oh , i checked inline 4.. its like 42 bux..... for the cable bracket and the cable..... just tryin to not spend that much if there is other ways..anyone else have experience with this?
Old Aug 19, 2004 | 02:19 PM
scratchy's Avatar
look a cable is a cable they all mount up the same its just as long as it is long enough or you might have a couple of extra feet in your engine bay but they all mount the same and they will all do there job
Old Aug 19, 2004 | 03:22 PM
khmboostedeh2's Avatar
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (scratchy)
http://www.ff-squad.com/tech/howto/sk2manifold/
Old Aug 19, 2004 | 03:31 PM
burningwrek's Avatar
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (Jeterkm02)
me and my friend put one on his 95 gsr and he had to use a type r throttle cable bracket.
Old Aug 19, 2004 | 03:57 PM
CrazyHB's Avatar
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (burningwrek)
whats up with the non GSR tb pulley? why would i need that.... i already ordered the bracket. thx for the info.
Old Aug 19, 2004 | 05:14 PM
scratchy's Avatar
well that is a kick *** write up on the whole swap, give those guys props
Old Aug 19, 2004 | 05:44 PM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyHB &raquo;</TD></TR><TR><TD CLASS="quote">whats up with the non GSR tb pulley? why would i need that.... i already ordered the bracket. thx for the info.</TD></TR></TABLE>
cause hte way the throttle cable pulls is toally diff between a gsr manifold and ohter honda manifolds.
Old Aug 19, 2004 | 05:49 PM
B_CRUZ!'s Avatar
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">
cause the way the throttle cable pulls is totally different between a gsr manifold and ohter honda manifolds.</TD></TR></TABLE>
Old Aug 19, 2004 | 06:05 PM
eg6ajk's Avatar
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (b cruz)
read up:
thanks to Katman again
Old Aug 20, 2004 | 07:21 AM
the reason you have to use the type r throttle body bracket is because the skunk2 intake mani put the throttle body too close to the gsr strut bar and the stock gsr throttle body bracket will hit it. the type r throttle body bracket make the throttle cable pull from the bottom rather from over head like the gsr throttle body does.
Old Aug 20, 2004 | 09:52 AM
itbtype-r's Avatar
use a bracket from a itr and cable from a 99-00 Si and a eg throttle cable pulley......
Old Aug 20, 2004 | 10:11 AM
Default Re: for a SKUNK 2 INTAKE MANI SWAP.. do i need.. (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">read up:
thanks to Katman again </TD></TR></TABLE>
beat you to it.
Old Aug 23, 2004 | 10:37 AM
itbtype-r's Avatar
lol,coo
90lsvcrxva
Apr 14, 2012 09:30 PM
eg6civic1538
Jun 30, 2007 02:50 PM
boomersz
16
Mar 10, 2007 08:08 PM
mattcivic
Jul 19, 2006 06:56 PM
gsr98teg
Feb 6, 2004 02:06 PM
