oil pan gasket question
im going to be replacing my oil pan gasket and was wondering will i need to take the exhaust off in order to pull the pan down or will i be able to manuver the oil pan around the exhaust. also do i need to use Hondabond when putting the new gasket on?? thanks
There should be a few nuts or bolts blocked by the pipes. Even if you could remove the nuts/bolts w/o removing the exhaust, I don't think it sits low enough to get the pan off of the studs.
pinoyboy204
29
Apr 28, 2017 07:14 PM
StreetRacinThug
Dec 21, 2006 08:44 AM
deconstruct
Jun 18, 2004 01:00 PM
