Hot or Cold Plugs?
Old Aug 19, 2004 | 09:57 AM
hybrid_vtec's Avatar
Default Hot or Cold Plugs?
For an all-motor car which spark plugs are better to run, a hotter or a colder spark plug? Just curious b/c I heard so many different answers from ppl! Some say hotter, while others say colder!
Give me some feedback and post what type of plugs you use/recommend and why?
Old Aug 19, 2004 | 10:06 AM
H22coupe's Avatar
Default Re: Hot or Cold Plugs? (hybrid_vtec)
I've had success running colder in my GSR both with a JRSC at 7 psi and with a different set-up all-motor at near 13:1 compression. Ran BKR7E-11's on both set-ups. Copper electrode, 1 step colder that stock GSR plug. Cheap too
Old Aug 19, 2004 | 10:14 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Hot or Cold Plugs? (H22coupe)
yes colder ngk's for everything
Thats the plugs I used when I used to spray on my old motor
Old Aug 19, 2004 | 10:59 AM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22coupe &raquo;</TD></TR><TR><TD CLASS="quote">I've had success running colder in my GSR both with a JRSC at 7 psi and with a different set-up all-motor at near 13:1 compression. Ran BKR7E-11's on both set-ups. Copper electrode, 1 step colder that stock GSR plug. Cheap too </TD></TR></TABLE>
cool i need new plugs too so now i know what to get
Old Aug 19, 2004 | 11:18 AM
Default Re: Hot or Cold Plugs? (HOOKUPS)
why is colder better
Old Aug 19, 2004 | 11:20 AM
Revhard92si's Avatar
Default Re: Hot or Cold Plugs? (vtec69)
I think cold plugs should only be used for force induction. When I squeeze and use cold plugs the car runs great. When I'm not squeezing and just running all-motor, using the cold plugs the car doesn't seem to be pulling as hard compared to regular plugs. That's just my opinion.
Old Aug 19, 2004 | 11:51 AM
H22coupe's Avatar
Default Re: Hot or Cold Plugs? (Revhard92si)
high compression n/a, boost, nitrous, all raise cylinder pressures and temperatures just by slightly different means
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revhard92si &raquo;</TD></TR><TR><TD CLASS="quote">I think cold plugs should only be used for force induction. When I squeeze and use cold plugs the car runs great. When I'm not squeezing and just running all-motor, using the cold plugs the car doesn't seem to be pulling as hard compared to regular plugs. That's just my opinion.</TD></TR></TABLE>
Old Aug 19, 2004 | 12:16 PM
93 VTEC's Avatar
The heat range of the plug indicates its ablilty to dissipate heat. If you are running high compression, boost, or nitrous, you want a plug that runs colder to suppress detonation. If you do alot of low speed (RPM) driving and aren't looking for maximum performance, use a hotter plug as it will run hot enough to burn off carbon deposits and prevent fouling. A heat range of 4(hot) - 7(cold) is what you want to stick with.
Old Aug 20, 2004 | 05:42 AM
Default Re: Hot or Cold Plugs? (93 VTEC)
Thanx if the info!
vietxdragon
Aug 13, 2006 07:57 AM
vgsr
Aug 22, 2005 04:25 PM
VSBB6
22
May 16, 2005 06:28 AM
import-tooner
Jun 28, 2004 04:38 PM
DeDonDeRosa
Dec 2, 2002 10:39 AM
