Burning Oil
Old Aug 19, 2004 | 09:06 AM
joshalee's Avatar
Default Burning Oil
I've done a search on burning oil, but still have some questions.
I have a 98 GSR.
I know that VTEC will burn the oil faster
I had 5w30 GTX in it and it was burning it like butter. No signs of leaking.
I just put in 3 quarts of 10w30 last week and noticed last night that my oil was at the lower level. Would I loose that much oil in a week? I'm engaging VTEC, but shifting at around 5000 RPM's daily.
Any thoughs. Leaks wouldn't necessarily mean it's dripping on the ground right? I noticed some fresh oil around my header
Old Aug 19, 2004 | 10:25 AM
SYTFU Tommy.'s Avatar
Default Re: Burning Oil (joshalee)
dont it need 4 quarts of oil? mayb thats ur problem by putting 3
Old Aug 20, 2004 | 06:45 AM
luckypon7's Avatar
yea your gsr needs 4 or 4.5 quarts
Old Aug 20, 2004 | 07:28 AM
simon98h22's Avatar
Default Re: Burning Oil (luckypon7)
Check your PCV valve.
Old Aug 20, 2004 | 10:12 AM
Savv's Avatar
yep I have the same problem on my 99 GSR....the thing eats oil like crazy...no signs of leaks either...about a month or less after i change the oil i gotta add another half quart to a full quart
right now I am using synthetic blend....
I dunno kinda sucks but I just check the oil often...
Old Aug 20, 2004 | 10:25 AM
simon98h22's Avatar
Default Re: Burning Oil (simon98h22)
Check the PCV ... like a 5$ part and can cause you to burn oil if it's plugged, easy way to check it: disconnect .... shake up and down ... if it don't rattle? Replace it. Should be done every 25K kms.
Si
Old Aug 20, 2004 | 10:29 AM
eg64u's Avatar
is the pcv valve the one that gos into your intake mani? not to sure but does anyone have pics of one i cant remember what exactly it is
Old Aug 20, 2004 | 11:59 AM
simon98h22's Avatar
Default Re: (eg64u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg64u &raquo;</TD></TR><TR><TD CLASS="quote">is the pcv valve the one that gos into your intake mani? not to sure but does anyone have pics of one i cant remember what exactly it is
Like a 1/4" hose that runs from the intake mani to the valve cover. PCV valve is the plastic L shaped piece that plugs into the valve cover.
If it's plugged, excess pressure cannot be recycled back into the intake manifold and burned off ... this causes the excess pressure to look for another way out IE your seals. Correct me if I'm wrong but I think that's the way it works. Not 100% on the science but I do know that a clogged PCV = burning oil
Si
Old Aug 26, 2004 | 12:04 AM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshalee &raquo;</TD></TR><TR><TD CLASS="quote">I've done a search on burning oil, but still have some questions.
I have a 98 GSR.
3 qts? wtf man..hmm may i dont know...1.8L gsr running 4.0 -4.5?qts not talking about the dann filter too............learn ur lesson....lucky u dont smoke ur ****
highwhey
Nov 11, 2010 05:53 AM
19integra94
Dec 26, 2008 01:51 PM
vinhtendo
Jan 11, 2008 08:01 AM
tdgcgpgsr
Aug 30, 2005 06:11 AM
osuPrelude
Oct 22, 2002 05:24 PM
