My friend got a bizarre engine swap, questions about it
Old Aug 19, 2004 | 08:06 AM
se3p's Avatar
Default My friend got a bizarre engine swap, questions about it
When he bought the car they said that it has a Si engine from HB 89, but we looked on the block and it's written ZC on it. Yesterday I noticed there's and additional port on the left side of the engine, near the intake manifold. On the head it's written SOHC 16V and the holes on the valve cover isn't like it is on ZC's, they are near the intake manifold, not the exhaust manifold. Now my question is, what the heck that head is? Is that a Si VTEC head with another valve cover? Also, is that port (about 1 inch diameter) near the intake manifold is for the VTEC. I'm new to Honda engine, I know about engines, but those are new to me. So, if that port is for vtec, how do we put the VTEC on it? Is there kits or used parts that will do the job? Also, is it better to have a VTEC controller in the car, not connected to the ECU? Another queston, if it's a ZC block with a Si VTEC SOHC head (mini-me?) how much HP is that engine putting up with VTEC activated?
Thanks a lot.
Old Aug 19, 2004 | 09:41 AM
se3p's Avatar
Default Re: My friend got a bizarre engine swap, questions about it (se3p)
near 40 reads and no reply? Does someone has a clue. I'm pretty sure someone knows what this port near the IM is. By the way, we'll work on his car tonite, so I'll take pictures, but if someone knows if that thing is for the VTEC and what parts he has to buy, he will buy those parts tonite, so it'll help us greatly in the process. Having a VTEC on a such small engine will help for sure.
Old Aug 19, 2004 | 09:59 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
actually they did produce a sohc vtec zc in japan they are 1.6liters and make about 115 to the wheels
Old Aug 19, 2004 | 10:11 AM
se3p's Avatar
Default Re: My friend got a bizarre engine swap, questions about it (HOOKUPS)
ok, but, is it normal that it's not written VTEC on the valve cover. And what valve cover layout does the SOHC VTEC ZC has? Are the spark plugs near the IM and where the oil cap is located. On his car, the oil cap is on the left side near the battery and the exhaust manifold.
Old Aug 19, 2004 | 10:14 AM
DYNO-PRO
the motor you are describing is not vtec the hole you are asking about could be for a mechanical fuel pump or egr valve pics would help
Old Aug 19, 2004 | 11:00 AM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by se3p &raquo;</TD></TR><TR><TD CLASS="quote">ok, but, is it normal that it's not written VTEC on the valve cover. And what valve cover layout does the SOHC VTEC ZC has? Are the spark plugs near the IM and where the oil cap is located. On his car, the oil cap is on the left side near the battery and the exhaust manifold.</TD></TR></TABLE>
just because it doesnt say vtec on the valve cover for SOHC doesnt mean its not a vtec
Old Aug 19, 2004 | 12:29 PM
99skunkedSi's Avatar
Default Re: My friend got a bizarre engine swap, questions about it (Manuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">I beat on a JDM DOHC ZC 1.6l Daily in a 90 hb si it a ltel qick car for the street taking out 99Si </TD></TR></TABLE>
whats that got to do with this tread??!!!
Old Aug 20, 2004 | 08:21 AM
se3p's Avatar
here are the pictures
Old Aug 20, 2004 | 09:29 AM
DYNO-PRO
that is a non vtec engine and the part of the casting on the head that you are reffering to was used for a mechanical fuel pump on the carburated version of that motor. i couldnt see in the pick if it is open but im guessing that it is just a blank hole in the head... nothing to worry about unless it is open then you must build a block off plate..HOPE THAT HELPED
carpenterkyle
13
Nov 7, 2012 10:04 AM
LittlesilverEF
Texas -OK -LA (Sales)
16
May 25, 2009 11:01 PM
srt4pilot
13
Apr 12, 2009 05:52 AM
Jmpage
21
Feb 20, 2005 07:52 PM
Ronin150
Sep 2, 2004 02:12 PM
