Eagle rod/ PR3 pistons combo question
Old Aug 19, 2004 | 05:47 AM
NSTY Z33's Avatar
Default Eagle rod/ PR3 pistons combo question
Well, i'm finiding it hard to find myself a set of PR4 rods around my area, not much classifieds.
Now my intentions were not to combine the eagle rod and my pr3 pistons together but my machine shop told me it can be done and showed me a sample of another customers. The guy can do the job. My question is wouldn't it be a bad thing in terms of maybe the piston being heavier than the rod??? I would also imagine the pistons would need balancing as well, since the crank is going to receive it too(rods too since they are balanced already). ????
Old Aug 19, 2004 | 12:48 PM
NSTY Z33's Avatar
bump
Old Aug 19, 2004 | 04:48 PM
NSTY Z33's Avatar
Default Re: (JDMCRXDelSol)
please hlp
Old Aug 19, 2004 | 05:07 PM
FURACERMAN's Avatar
Default Re:
Huh? Yes the pistons will work with those rods.
Old Aug 19, 2004 | 08:43 PM
crazyitr's Avatar
Default Re: Re: (FURACERMAN)
Those rods suck. I lost a motor when the rod bolts broke. Use Crower Econorod (Erick's spin these to 11,000 rpm).
Old Aug 20, 2004 | 12:48 PM
FURACERMAN's Avatar
Default Re: Re: (crazyitr)
Do you know what you just said? It was the rod bolt...
Old Aug 20, 2004 | 12:59 PM
NSTY Z33's Avatar
I def do not think crower is worth what they charge honestly. I've heard sucess stories with eagles spinning to 10.5k no problem, yet again i've seen posts with holes in blocks wit the crowers.
Old Aug 20, 2004 | 02:44 PM
lemongreenhatch's Avatar
Default Re: Re: (JDMCRXDelSol)
yes this combo will work will have to be balanaced i have ctr's on eagle rods
Old Aug 20, 2004 | 10:31 PM
crazyitr's Avatar
Default Re: Re: (poorman-type-r)
I did say the rod bolts. There are a lot of eagle rods floating out there with those bolts. If you pay for the upgrade, you might as well by better rods that come with the better bolts. Where are eagle rods made anyway? China
Old Aug 20, 2004 | 10:36 PM
99skunkedSi's Avatar
i dont mean to thread jack but what does a gsr rod weigh compared to the econorods?
diatibe24
Feb 24, 2017 11:47 PM
kpjo4
Mar 11, 2010 07:56 PM
SiR99
Sep 1, 2006 09:17 PM
boost fed ls
Jan 29, 2005 04:20 AM
VWkila
Jan 28, 2003 08:42 AM
