HELP! motor trouble
I just finished swapping a sohc vtec in my 88 hatch and the motor relines at 3200 rpm. It doesnt rev pass that. I have codes 4, crank angle sensor and, 41, O2 sensor heater.
Did you search.
BTW Fix the Code 4 and it will Raise the Redline to were it Shuold be. I know this could have been found if you Search seeing as it has been covered many times befor.
https://honda-tech.com/zerothread?id=958473
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryse68 »</TD></TR><TR><TD CLASS="quote">I just finished swapping a sohc vtec in my 88 hatch and the motor relines at 3200 rpm. It doesnt rev pass that. I have codes 4, crank angle sensor and, 41, O2 sensor heater.</TD></TR></TABLE>
d16z6 or d16y8 motor?
what ECU, what distributor? details details!!
I reconnected the two distributor wires today and used my friends chipped PO6 for a gsr and it ran fine, no codes, vtec kicking in at 4400. When I plugged my ecu which is a stock vx it ran shitty and did rev pass 3200, AGAIN. I figure that its the ecu. Would the problem go away if I have the ecu chipped?
panda_eh2
Nov 11, 2009 12:01 AM
Rayz_Si
19
Dec 28, 2006 10:34 PM
Funkmasterjay
Jun 10, 2004 02:44 PM
