DOHC ZC start problem
Old Aug 18, 2004 | 09:37 PM
HondaKPX's Avatar
Default DOHC ZC start problem
i jsut swaped in my DOHC ZC into my 89 CRX Si. and i go to start her up and she cranks but doesnt start. checked and there is spark and feul. So i went to the ECU to check for codes and the battery died. its charging and ill keep you updated on codes tomarow.
Old Aug 18, 2004 | 10:34 PM
sabertooth's Avatar
Default Re: DOHC ZC start problem (HondaKPX)
did u take the wire out of the distributor connector for the cam angel sensor? im in chandler so i may be of some help
Old Aug 19, 2004 | 11:17 AM
boonacka's Avatar
Default Re: DOHC ZC start problem (sabertooth)
your dizzy wires are probably mixed up. its a common and simple mistake.
Old Aug 19, 2004 | 01:38 PM
HondaKPX's Avatar
well i chenged the plug order and it started and then died. it will stay alive as long as i keep the rpm's over 1500 but when it does run its pretty shitty. no codes being throw eather. any ideas?
Old Aug 19, 2004 | 02:27 PM
HondaKPX's Avatar
Need help bump
Old Aug 19, 2004 | 04:16 PM
HondaKPX's Avatar
just new news, i got it to by taking the vacume line off the choak. runs horribly but it runs. also, its throwing a code 7. TPS sensor if im not mistaken. well i was kinda expecting that because when the motor was shipped the sensor was off and the gasket was fubar. so i figured id go without a gasket. now that its throwing the code im getting a gasket and seeing what it does now. all help is greatly appreciated.
stickman78114
Feb 25, 2010 04:23 PM
StraightCivic
Mar 27, 2006 05:58 PM
h22_crx
Oct 12, 2005 11:56 AM
wrightwx
Sep 14, 2005 11:36 AM
