High Revvin my D
I think it would depend too much on what motors you were talking about. A SOHC D series from an Si probably wouldn't suffer as much damage than say a DOHC B18B because its a mo betta motor as far as engineering, build quality and materials.
Mostly I'm talking about damage to valves/springs/cams etc. up there in the top part.
what constitutes high revving. On a b series it is easier to rev them high than on a d-series, kinda like 8200 rom on a d is the equivalent of 9200 on a b, understand?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">what constitutes high revving. On a b series it is easier to rev them high than on a d-series, kinda like 8200 rom on a d is the equivalent of 9200 on a b, understand?</TD></TR></TABLE>
Just curious, are you basing that analogy on piston speeds resulting from rod/stroke ratio?
I have never actually bothered to look up the r/s of a d series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NLR808 »</TD></TR><TR><TD CLASS="quote">to build a dohc killer your sohc must be high reving</TD></TR></TABLE>
And your car has to be as light as possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scurvydog »</TD></TR><TR><TD CLASS="quote">are you talking about high reving as in past the redline or below it?</TD></TR></TABLE>
Anything below rev cut won't hurt it.
To my understanding, the B7 valvetrain is probably good to 7300 or so and the Z6 to around 8,000. However, I wouldn't rev it that high unless I upgraded my springs and retainers.
The D15B's has a R/S of 1.59
The D16's have a R/S of 1.52
The JDM D15B has a R/S of 1.62
FYI...the B18B's r/s ratio is 1.54 and the B18C's is 1.58. The B16 has the best R/S ratio with a 1.75
The D15's are better for high revving than the D16's, but if you're going to be revving it up to or past 8 grand, you need upgraded valvetrain, rod bolts, ECU, and a camshaft that makes power that high.
Not true...boost ownz joo!
well thats good. soo hypothetically speaking of course, if i need the extra revs for a quater mile it would be realitivly safe to shift around 7500-7800 without valve train upgrades?
I have a D16z6 btw
I have a D16z6 btw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scurvydog »</TD></TR><TR><TD CLASS="quote">well thats good. soo hypothetically speaking of course, if i need the extra revs for a quater mile it would be realitivly safe to shift around 7500-7800 without valve train upgrades?
I have a D16z6 btw</TD></TR></TABLE>
no, more like 6900.
no, more like 6900.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelJComputer »</TD></TR><TR><TD CLASS="quote">
no, more like 6900.</TD></TR></TABLE>
According to bone, the stock valvetrain takes a **** around 8200 RPM. Also, the springs are apparently okay it is just the retainers that need to be upgraded. In any case, if one is going to be taking past the 7350 fuel cut they should get upgraded springs and retainers.
On a stock camshaft though, it is worthless to take it past 7000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">On a stock camshaft though, it is worthless to take it past 7000.</TD></TR></TABLE>
but revving higher makes it faster!
but revving higher makes it faster!</TD></TR></TABLE>
Only with this:
BTW Mike: Check ur pm's from me!
Only with this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp »</TD></TR><TR><TD CLASS="quote">Bauley, Do you knw of any aftermarket cams for the Y5? I really wanna build mine up, but there's just no market for that motor it seems.</TD></TR></TABLE>
There are none, I believe you gotta contact like crower or crane and have them custom make you one to your specs.
