DOHC ZC compatibility
are the internal parts of a zc interchangeable with all d-series internals?
im getting a bare DOHC ZC block and head and i want to just put it back to stock for now (internal wise) so i can drop it in my rex. thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdx89 »</TD></TR><TR><TD CLASS="quote">BUMP
can any d-series pistons go in this?</TD></TR></TABLE>
Yes.
75mm standard bore
Yes.
75mm standard bore
what valvetrain will go in the head? this is not a d16a1 either, its true DOHC ZC thanks for ur input. what about pulleys, harmonic balancer, rods, etc etc. anything and everything u kno about DOHC ZC's pass it on to me!!!! i would search but the motor is gona be here in an hour or so and i want to start ordering parts!!!!
I believe the head and valvetrain to be different from the rest of the D-series, because it's the only DOHC D series.
Check out this page, it's very good for ZC info:
http://www.thezcr.com
No,
The PM7 pistons are the only honda made pistons which will give you the right compression. All of the others, (A6, Y8, D15b), will lower compresssion. I believe the D16A6 rods are the only ones that will work. I'm not sure about the crank.
ok, to clarify, this is what i have:
DOHC ZC block, crank, all hardware
DOHC ZC head, valves, springs, retainers, and all the headbolts, water pump and that kind of stuff.
i paid 25 bux for all of it.
now tell me what i need to make it work lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">The PM7 pistons are the only honda made pistons which will give you the right compression. All of the others, (A6, Y8, D15b), will lower compresssion. </TD></TR></TABLE>
This is because ZC pistions are domed.
You can use the pistons, rods and all the gaskets and seals for a 88-89 Integra D16a1 motor. If you look around you can get a set of DOHC ZC or D16a1 rods and pistons used for $100-$150. If I were putting this motor together I would pick up a set of eagle rods for a d series motor and a set of Wiseco pistons for a 88-89 Teg.
If you want to sell that motor I will give you double what you paid for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">No,
The PM7 pistons are the only honda made pistons which will give you the right compression. All of the others, (A6, Y8, D15b), will lower compresssion. I believe the D16A6 rods are the only ones that will work. I'm not sure about the crank.</TD></TR></TABLE>
p29 will also work, i just met a guy with sohc zc with p29
