Just installed led's for gauges
Old Aug 18, 2004 | 07:21 PM
iwannaboostmyteg's Avatar
Default Just installed led's for gauges
Ok so I bought 3 amber led's from http://superbrightleds.com I just got them in today so I put them in and here's the result of my $9.77 investment. I'm pretty disappointed with how they turned out but I still like it better then just plain old white. Notice how its brighter in some spots then others so I'm thinking of just getting amber bulbs instead because I was hoping that this would turn out bright but instead it turned out Gay...
Old Aug 18, 2004 | 07:22 PM
iixerOii's Avatar
Default Re: Just installed led's for gauges (iwannaboostmyteg)
Should of just gotten oem Amber 194 replacements. Mines let up bright and orange (amber yO) now. But anything is better than stock. I don't think the LEDs are that great because their beam in concentrated instead of spread out like regular bulbs. Since the main parts of the cluster shares 3 bulbs, LEDs could be inefficient.
Old Aug 18, 2004 | 07:31 PM
sykotic's Avatar
get sand paper and scuff up the LED all around, this should help spread the light instead of it concentrating straight ahead, if this doesn't help anymore, you can try sanding the tip of the LED flat instead of domed how it is.
Old Aug 18, 2004 | 07:34 PM
sykotic's Avatar
did you just buy LED's or did you get 194 LED bulbs?
Old Aug 18, 2004 | 07:36 PM
xteg95's Avatar
Default Re: (sykotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">did you just buy LED's or did you get 194 LED bulbs?</TD></TR></TABLE>
im pretty sure you can only put 194's in there, i bought some from autozone and they looks fine to me.
Old Aug 18, 2004 | 07:45 PM
I bought the 194 led's is like 4 led's in one instead of just one bulb. I'll try that sanding thing out but I'm gonna take the 194 turn signal amber bulbs I got and put them in to see if I want to just go with amber's or not. here's the link to the specs on the bulbs http://superbrightleds.com/specs/bulb_specs.htm
Old Aug 18, 2004 | 07:49 PM
sykotic's Avatar
i think the single LED bulb would've worked better, could be wrong
Old Aug 18, 2004 | 07:56 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
bulbs are better here because you're looking for light diffusion, which is not what LEDs are made for.
Old Aug 18, 2004 | 08:15 PM
.water's Avatar
some of LED is very bright and spray well. some of LED isnt. just very bright one spot. btw what is good for amber looking? what kind bulb? i was getting red bulb from WAL-MART .heh
Old Aug 18, 2004 | 08:40 PM
Westrock2000's Avatar
Default Re: Just installed led's for gauges (Spoon TypeOne)
I bought two red bulb replacements and painted the 3rd (cause they only had 2 of the red left)....I love it, it is much easier to see at night....not as glaring.
Old Aug 18, 2004 | 10:35 PM
iBrandon's Avatar
Default Re: Just installed led's for gauges (Westrock2000)
I just put my super white led in 10 mins ago heres what they look like...Your rite they dont have an even light all around...i mite try sand paper like u said...but iono i like em...its better then the greenish white i can live with it..
Old Aug 18, 2004 | 10:41 PM
Beezle's Avatar
Default Re: Just installed led's for gauges (Shy Gsr)
Man I was just going to buy the 6 led ones. I guess not, looks like I'm gonna go get some new 194 amber bulbs since mine are getting dull.
Old Aug 18, 2004 | 11:00 PM
SHystrdyGSRtdy's Avatar
Default Re: Just installed led's for gauges (Beezle)
use some cotton ***** and spread it out pretty finely... you should get an even spread
Old Aug 18, 2004 | 11:05 PM
iBrandon's Avatar
Default Re: Just installed led's for gauges (SHystrdyGSRtdy)
what u mean cotton *****??? explain a little more...
Old Aug 18, 2004 | 11:25 PM
you know when you pull apart cottonballs to get the spiderweb effect during halloween? do the samething for the led's
Old Aug 18, 2004 | 11:29 PM
iBrandon's Avatar
ok gotcha...ill try it thanks!
Old Aug 18, 2004 | 11:57 PM
so your saying to get "actual cotten *****" and spread them out in the cluster? I'm guessing your saying this so that the light will catch the cotten and thus give the illumination a more spread out look.
Old Aug 19, 2004 | 04:38 AM
jdm_cars's Avatar
haha.... dude, I know how you feel. I am a victim too.....
But you know what, I didn't buy them cheap 9.00 LEDs.
I bought two sets of JDM PIAA 4LED bulbs to put in my Gauges thinking they would be damn brighter.... like 40bucks for two pairs.
I got the same shitty results as you, LEDS don't shine all around in the Cluster housing and got some bright and dim areas like yours.
I'll Give you a tip.... I just ended up switching to Raybrig Super White Halogens, Much better, and super bright!
Old Aug 19, 2004 | 05:42 AM
ecahatch's Avatar
Senor Miembro
the white LED looks cleaner
Old Aug 19, 2004 | 12:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwannaboostmyteg &raquo;</TD></TR><TR><TD CLASS="quote">so your saying to get "actual cotten *****" and spread them out in the cluster? I'm guessing your saying this so that the light will catch the cotten and thus give the illumination a more spread out look.</TD></TR></TABLE>
correct
Old Aug 19, 2004 | 06:28 PM
Beezle's Avatar
Has anyone tried this yet? Does it really spread the light out good?
Old Aug 19, 2004 | 07:34 PM
hollis's Avatar
yeah dude you shouldnt of gotten leds, you should of stuck with regular amber bulbs
Old Aug 19, 2004 | 08:36 PM
njandrewg's Avatar
Default Re: Just installed led's for gauges (hollis)
just get bulbs, much better results
can't really see the change in lighting in person
Old Aug 21, 2004 | 02:01 PM
HeyMikeyyyy's Avatar
Default Re: Just installed led's for gauges (njandrewg)
Not amber but red 194 bulbs at auto zone
Modified by HeyMikeyyyy at 3:56 AM 9/14/2004
Old Aug 21, 2004 | 03:21 PM
.water's Avatar
Default Re: Just installed led's for gauges (HeyMikeyyyy)
damn..that looks good....is that same thing from WAL-MART??
