Did search already Mixed up parts for rear disc. Are they all interchangeable?
Old Aug 18, 2004 | 05:18 PM
SkoundrelUSA's Avatar
cute little bastard
Default Did search already Mixed up parts. Are they all interchangeable?
Sorry if this is repeat for you guys, but I already did a search and my situation is a bit different. I have a rear disc conversion sitting in my house with pretty much everything for my 94 Civic VX but all the stuff I have is off different cars. Tell me if I'm gonna have a problem with any of this stuff:
1) Complete trailing arm, calipers, rotors, hub and spindle off a 94 Civic SI. + Stainless Steel lines for 92-95 Civic with rear disc
2) e-brake cables off a 96 Integra
3) Master cylinder and brake booster off 93 Integra GSR (ABS)
4) 40/40 proportion valve off 93 Integra LS
I'm really paranoid so I just want an opinon from some of you guys. Am I going to have any major problems or am I all set? Thanks in advance
Modified by SkoundrelUSA at 10:46 AM 8/19/2004
Old Aug 19, 2004 | 09:46 AM
cute little bastard
Default Re: Did search already Mixed up parts. Are they all interchangeable? (SkoundrelUSA)
bump
Old Aug 19, 2004 | 09:52 AM
JDMH22HATCH's Avatar
1, 2, and 4 are good, but I have no clue about the 93 GSR mc/bb. Do a search for Tom aka "b18c5-eh2" he did a good write up on which are all interchangeable
Old Aug 19, 2004 | 06:59 PM
cute little bastard
I tried searching but I cant find it. only a thread about using a 91 ex cylinder into a SI. can someone help me out please...
Old Aug 19, 2004 | 07:11 PM
NonovUrbizniz's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Sorry if this is repeat for you guys, but I already did a search and my situation is a bit different. I have a rear disc conversion sitting in my house with pretty much everything for my 94 Civic VX but all the stuff I have is off different cars. Tell me if I'm gonna have a problem with any of this stuff:
RTA's will work fine
I'm sure they'll work... but they may not bolt in exactly
Yes it will work but the ABS will make it more of a pain as the flared ends are different sizes... your stock non-abs lines are smaller they will seat but they may leak... to do it right You'll need to re-flare the lines.. which is a BITCH
will work fine but will not bolt up properly... you'll need to either use one bolt or mount it to a piece of band metal and drill the properly spaced holes in the band metal... I used the same prop valve in my swap (all parts from a 93 LS to a 93 civic ex).
Modified by SkoundrelUSA at 10:46 AM 8/19/2004</TD></TR></TABLE>
You should be all set... not as easy as it could be but not the worst thing in the world either.
Old Aug 20, 2004 | 10:22 AM
cute little bastard
Default Re: Did search already Mixed up parts. Are they all interchangeable? (NonovUrbizniz)
Hmm interesting.... thanks for the info. anyone else?
Show15
Suspension & Brakes
15
Apr 6, 2010 10:05 AM
what1118
Jan 17, 2009 01:55 PM
spyderman_8_2
Jul 7, 2006 08:26 AM
goldenk10
Jul 19, 2004 12:54 PM
Stryker908
Nov 21, 2002 06:09 PM
