Side Markers
I believe That these pics are from CRXGator. Not sure if he was the origional poster but I saved them knowing someone would need them later. Sorry if he wasn't the person who posted these but for some reason the name popped into my head.
just splice a power and ground off of corner bulb on each side of the car, run a length of wire from the corner lense to the sidemarker somewhere in side the fender well.
couldnt be any simpler
p.s..im not sure how the 4 doors are but the USDM crx's have 2 bulbs in the corner lense..one stays lit and flashes...and the other one just flashes (i think..its been a while since ive had a usdm front end)...
EDIT: (left the last part out) so tap into the one that stays lit and flashes when the signal is activated
Modified by X-Static at 12:19 AM 8/19/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static »</TD></TR><TR><TD CLASS="quote">just splice a power and ground off of corner bulb on each side of the car, run a length of wire from the corner lense to the sidemarker somewhere in side the fender well.
p.s..im not sure how the 4 doors are but the USDM crx's have 2 bulbs in the corner lense..one stays lit and flashes...and the other one just flashes (i think..its been a while since ive had a usdm front end)</TD></TR></TABLE>
Agreed on the simpler part
and
the JDM 4 doors only have one bulb at the corner and the USDM are like Rex's and Hatches with both lights at the corners
and
