egr lift sensor
Old Aug 18, 2004 | 05:04 PM
sIcWiTiT's Avatar
Default egr lift sensor
ok. i have posted about this topic before trying to get someone to give me a pic of the egr lift sensor. i decided that it would be best to just take a pic of what i think the egr lift sensor is and have somebody out there identify it. heres the pic dudes. is this the egr lift senor?
thanks
Old Aug 18, 2004 | 05:21 PM
junbb1's Avatar
Default Re: egr lift sensor (flosSIn)
that is not the lift sensor. that is the egr control solenoid. the actual lift sensor is located in the egr valve.
the lift sensor gives a voltage reference feedback to the ecu to let it know its posistion, therefore allowing the ecu to compensate.
Old Aug 18, 2004 | 05:23 PM
AndyD's Avatar
Here, they list it as the valve assembly.
http://www.hondaautomotivepart...EVICE
Modified by AndyD at 5:12 PM 9/8/2004
Old Aug 18, 2004 | 05:53 PM
sIcWiTiT's Avatar
Default Re: egr lift sensor (AndyD)
if i dont have the control device hooked up then i should be getting a 12 cel right? where do the pins on the control device go to on the ecu? any help is appreciated.
thanks
Old Aug 18, 2004 | 06:17 PM
sIcWiTiT's Avatar
up for need info
Old Aug 18, 2004 | 10:48 PM
sIcWiTiT's Avatar
up for the night crew
Old Aug 19, 2004 | 10:41 PM
sIcWiTiT's Avatar
ttt
Old Sep 8, 2004 | 12:58 PM
Qveon's Avatar
you have an EGR solenoid for sale? I need one.
Old Sep 2, 2006 | 03:13 PM
djnikko's Avatar
Default Re: egr lift sensor (Qveon)
Im after one too
PM me if you have one
Old Sep 2, 2006 | 03:16 PM
prelude1897's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qveon &raquo;</TD></TR><TR><TD CLASS="quote">you have an EGR solenoid for sale? I need one.</TD></TR></TABLE>
I have one..If you're interested, just let me know. PM me or email me at romanticpimp@hotmail.com
Old Sep 2, 2006 | 05:30 PM
BB6racer's Avatar
got some pinout for you. they are located in the civic/del sol forum right by the forum rules, FAQs, etc...
https://honda-tech.com/zerothread/1171263
Old Sep 2, 2006 | 07:11 PM
skinnyboy's Avatar
Default Re: egr lift sensor (sIcWiTiT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sIcWiTiT &raquo;</TD></TR><TR><TD CLASS="quote">ok. i have posted about this topic before trying to get someone to give me a pic of the egr lift sensor. i decided that it would be best to just take a pic of what i think the egr lift sensor is and have somebody out there identify it. heres the pic dudes. is this the egr lift senor?
thanks
Thats the Fuel Rail Bypass valve is it not, from a JDM H22? Replaces the Starting Air valve as found on the USDM and AUDM inlet manifolds.
Old Sep 3, 2006 | 06:42 AM
Duane_in_Japan's Avatar
Default Re: egr lift sensor (skinnyboy)
I believe that if the ECM commands the EGR open during decel and it does not see any motion via the lift sensor since you have disconnected something in the circuit then yes, it will still set a code.
I have heard of folks removing the EGR and plugging off the area with a cover plate and just let the EGR hang, or secure it somewhere. If your OBDII system soes not look for a temp change beyong the EGR to monitor valve opening or if your system does not monitor MAP voltage for a change in vacuum during EGR operation then you should be OK, emissions will be affected but may not affect you.
Old Sep 3, 2006 | 08:49 AM
djnikko's Avatar
Default Re: egr lift sensor (Duane_in_Japan)
Is there any explanation threads on IAB, IAC, EGR, Purge etc etc. I would liek to knwo how they are all linked together and which are needed to make the car run and which are needed just for emissions.
Thanks
Old Sep 3, 2006 | 02:35 PM
Qveon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skinnyboy &raquo;</TD></TR><TR><TD CLASS="quote">
Thats the Fuel Rail Bypass valve is it not, from a JDM H22? Replaces the Starting Air valve as found on the USDM and AUDM inlet manifolds.</TD></TR></TABLE>
This man is correct. The EGR solenoid is located on the driver's side shock tower.
Oh and no i dont need the valve anymore. I created a bypass method.
Old Sep 3, 2006 | 04:00 PM
djnikko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qveon &raquo;</TD></TR><TR><TD CLASS="quote">I created a bypass method.</TD></TR></TABLE>
How did you do that out of interest?
Where can I learn more about the differing sensors on engines from different markets/countries? I have a JDM H22A and Im sure Im missing a bunch of sensors. The cars in the workshop now and having the engine put in place and I can just tell its gonna throw a load of codes!
sIcWiTiT
Sep 4, 2006 05:39 AM
sIcWiTiT
Sep 2, 2006 03:09 PM
J4k3
16
Jun 22, 2006 08:25 AM
Audi A4
Apr 21, 2004 08:45 AM
civic-dx
Jul 31, 2003 09:27 PM
