95 Ex Starts fine for weeks then ABSOLUTLY NOTHING
Old Aug 18, 2004 | 04:29 PM
conlanx's Avatar
Default 95 Ex Starts fine for weeks then ABSOLUTLY NOTHING
Turn the key, lights come on fuel pump turns on but when you try to start...nothing, no clicking nada.
I can pop the clutch and it starts up fine and sometimes after that, its back to normal but other times, still nada.
Kicker is once its started and runs after a nonstart episode-(sometimes) after shutting it off and trying to restart nada but if it sits for awhile it starts right up without even kicking the dang thing. HELP
Old Aug 18, 2004 | 04:45 PM
hondadude's Avatar
Default Re: 95 Ex Starts fine for weeks then ABSOLUTLY NOTHING (conlanx)
First thing to do is check the battery terminals and ground/starter connections. What you need to prove is if you are getting power to the starter solenoid when the problem occurs. A test light will tell the tale. If there isn't power getting to the starter solenoid, the ignition switch could be going bad. If there is power at the starter solenoid, the starter contacts are bad.
Old Aug 18, 2004 | 04:57 PM
hondaracin24's Avatar
Something simaler that you have described has happened to me. It turned out to be the starter. It only occurs once and awhile and then when you least expect it doesnt want to start. Has your starter ever been replaced before?
Old Aug 18, 2004 | 06:24 PM
jwogen1's Avatar
Default Re: (hondaracin24)
alternator maybe?
Old Aug 21, 2004 | 08:45 PM
PnX-R's Avatar
when it doesn't start, hit the starter with a hammer to jar it. if it starts, check for loose & corroded connections. if none, replace starter.
jeffcat
11
Jun 11, 2019 07:15 AM
EGed up from the seat up
May 13, 2010 11:34 PM
azandford
Apr 29, 2010 06:03 AM
joexjoex44
10
Jan 2, 2010 10:00 PM
morphics
34
Nov 4, 2005 05:41 AM
