Help! Engine code 8 won't go away!!!!!
Old Aug 18, 2004 | 02:36 PM
integraracing91's Avatar
Default Help! Engine code 8 won't go away!!!!!
I got an engine code 8 after trying to start up my swap of a 92 Acura Integra LS motor into an 89 CRX Si.
I followed the <U>Integra</U> Helms manual to test out the problem areas and they all checked out fine. I reset the ecu, checked the resistance and continuity of everything the manual said to test.
Then the final step was "substitute a known-good ECM and recheck" now if ECM also means ECU then I already tested it in a friends car(93 integra LS) and his car started up and ran perfect.
ANY IDEAS ON WHAT THE PROBLEM IS????????
Thanks for any help
Old Aug 20, 2004 | 10:16 AM
Default Re: Help! Engine code 8 won't go away!!!!! (integraracing91)
Bump
Old Aug 20, 2004 | 05:13 PM
No ideas then =\
bcintron95
Nov 17, 2013 02:04 PM
silent-chris
Dec 1, 2004 06:39 PM
USDM 4G VTEC
Aug 16, 2003 10:29 PM
Jockobo
Jun 29, 2002 12:38 AM
