help problem with swapping gsr brakes into eg,caliper keeps locking up
i just swaped over a complete integra front and rear brakes into my hatch with 40/40 prop.valve,15/16 mc and e brake lines but my right front caliper keeps locking up.i bench bled the master,and complete brakes. when i press on the brakes the right side caliper doesn't want to realease from the rotor. i tried 2 different integra calipers, same problem. anyone have any ideas on what might be the problem.
well if you tried 2 different calipers, that aint the problem. Check your brake lines. if they are bled and your sure there ok, your problem is more downstream. Check the prop valve, see if its clogged or whatever. If not, run fluid through the BB and make sure its pumpin fluid all the way. you gonna have to check this **** by dissasembly.
91civicDXdude
Jun 24, 2003 07:26 AM
