where to buy "1 layer" headgasket
i have seen alot of people using 1 layer headgaskets, i was wanting to know where to get one.
i know spoon, and mugen make them but i dont wanna pay 200.00 bux for a headgasket. so where else or who else makes em?
I don't know if .027 inch is considered 1 layer or not; but here you go
http://www.nipponpower.com/eng....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicNA94TegGsR »</TD></TR><TR><TD CLASS="quote">how much does that raise compression?</TD></TR></TABLE>
not enough to be worth the risk of it blowing out on you....
I would guess that its gona be a bitch to have it seal in the long run. just mill the head and run a 3 layer. there are a few big engine builders that dont even recomend running 2 layer gaskets...
I use a single layer headgasket, I have reused it a few times. my car is not a street car.
I think 2 layer should be a minimum on a street car, and its not a good idea to reuse a headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 »</TD></TR><TR><TD CLASS="quote">i have a re-used two layer headgasket, no problems here, just buy some copper gasket spray from Pep-Boys.
that copper **** is so bad to use...
</TD></TR></TABLE>that copper **** is so bad to use...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon »</TD></TR><TR><TD CLASS="quote">
that copper **** is so bad to use...</TD></TR></TABLE>
why is that?
why is that?
I disagree completely
It's not bad to use if used properly. everyone thinks more is better, thats not the case. A very thin even coating is all thats needed. If overapplied, it will end up pushing into all the passages and make its way down to the oil pan where it will get clogged into the oil pickup...Seen it happen many times.
Man i would think you would have to use the whole can? But i sed it and all my other friends have and no problems as of yet.
lude98SH
Feb 8, 2007 08:49 AM
SupaFly_Honda
Nov 2, 2003 09:04 AM
