d16y8 Swap question
i have a y8 and i was wonrdering if i chould stick in my d15b6 fuel rail and use obd1 injectors that came with the d16y8 cause the y8 for some reason didnt come with a fuel rail.so my question is, is the d15 fuel rail is compatable with the d16y8 intake manifold along with its obd1 injectors?, oh yea, i got the obd1 conversion too if that helps.
i'm not at all sure but i'm gunna say not. i know on a mini-me swap if you are going to OBD1 you gotta use the y8 rail with the y8 IM. someone correct me if i'm wrong....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">i have a y8 and i was wonrdering if i chould stick in my d15b6 fuel rail and use obd1 injectors that came with the d16y8 cause the y8 for some reason didnt come with a fuel rail.so my question is, is the d15 fuel rail is compatable with the d16y8 intake manifold along with its obd1 injectors?, oh yea, i got the obd1 conversion too if that helps.</TD></TR></TABLE>
No. You need the Y8 fuel rail. Make sure you get a M/T manifold as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">and use obd1 injectors that came with the d16y8 </TD></TR></TABLE>
A little confusing so some clarification.
Y8 is OBD2 with OBD2 injectors.
OBD1 injectors will fit and work.
OBD1 rail will not work on Y8 manifold.
oh your right,so what do you guys suggest i get for my obd1 ecu, like injectors and fuel rail wise, what should i use and where can i get? Thanks
marcus029
Mar 6, 2008 07:08 AM
iphatcrxi
Nov 14, 2006 10:09 AM
madcrossover
Mar 9, 2006 07:48 AM
unsungsohc
Jul 11, 2004 11:27 PM
