what aftermarket clutches are you using???
Old Aug 18, 2004 | 06:56 AM
deadbymorning's Avatar
Default what aftermarket clutches are you using???
i can finally feel my clutch slipping a bit so its time to upgrade. let me run down my set up, 96 ex 4-door 5-speed, tenzo/HKS intake, royal purple fluids , just all the little stuff (saving for h22 swap). ive been looking at the competition clutch gravity kit. they claim a 40% torque capacity increase over stock. the kit only runs me about 200 bucks but i wanted to know everyones take on different clutches.
Old Aug 18, 2004 | 07:36 AM
ZigenBallz's Avatar
Default Re: what aftermarket clutches are you using??? (deadbymorning)
I'm running an exedy organic racing clutch w/ a fidanza 8lb flywheel... nice clutch pretty grippy so far and the pedal feels like stock...
I highly reccomend that combo...
Old Aug 18, 2004 | 07:55 AM
10 psi's Avatar
Default Re: what aftermarket clutches are you using??? (ZigenBallz)
how much diff is driving wit a 8 lb flywheel???
Old Aug 18, 2004 | 08:47 AM
ZigenBallz's Avatar
Default Re: what aftermarket clutches are you using??? (Ricers Blow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricers Blow &raquo;</TD></TR><TR><TD CLASS="quote">how much diff is driving wit a 8 lb flywheel???</TD></TR></TABLE>
Alot different... alot better actually... the pros far outweigh any negatives..basically the only bad thing I have noticed is that you have to downshift when going up steep hills, that's it... but for the increased revving & revmatching and better acceleration it's a small price to pay... you haven't experienced true revmatching or heel toeing until you've driven with a light flywheel...
If I could only have one mod... that would be it...
Old Aug 18, 2004 | 09:23 AM
i was looking at the competion clutch flywheel also, only 200 bucks through my work, but i cant find any specs on it. anyone familiar with this flywheel? thanks also for your input ZigenBallz, ill check out what kind of deal i can get your setup for since you are pleased with it. i just want to make sure i can still drag the clutch a little bit, ive got a friend with a clutchmasters stage 3 clutch and its like a light switch, no engagement at all. mine is a daily driver and i live in the city so i need something very streetable.
Old Aug 18, 2004 | 10:21 AM
exedy stage 1 organic clutch kit for 175 through my work.. sound like a good deal ZigenBallz???
ps- i am assuming you are refering to their stage 1, correct me if im wrong
Old Aug 18, 2004 | 01:39 PM
pnut's Avatar
CM stg 3
CM flywheel
lovin every minute
Old Aug 18, 2004 | 01:56 PM
KTeller8's Avatar
Default Re: what aftermarket clutches are you using??? (pnut)
action clutchs all day long~
also the competion clutch guy/founder used to work for CM, so if you dont like the CM you wont like the competion clutch, its basically the same thing just lowballed!
Old Aug 18, 2004 | 02:31 PM
pnut's Avatar
Default Re: what aftermarket clutches are you using??? (KTeller8)
i don't see anything wrong w/ my CM so far. i only have 80 miles on it, though...
i've seen a couple stories of dis-lodging some springs on the friction disc, but i'm sure that was under some extreme abuse
Modified by pnut at 9:40 PM 8/18/2004
Old Aug 18, 2004 | 03:37 PM
97F22B2's Avatar
ACT HDSS with Streetlite flywheel
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Mar 2, 2015 05:02 PM
juniestyle
Apr 14, 2007 10:42 AM
Atheist
Feb 3, 2005 12:41 PM
JdmAcclude
May 6, 2004 12:03 PM
redlineh22a
Feb 20, 2003 08:46 PM
