Does this look like a good dea? b-series mount for 225.00 +S/H
Honda 88-91 CRX/Civic B16a/B-Series Motor Mount Kit 225+15 s/h
http://cgi.ebay.com/ebaymotors...83591
Modified by Matrix_Zero at 2:56 PM 8/18/2004
if you are on a budget, these will work, but if you want quality, and from my own personal experience, i don't think you will see one complaint regarding hasport.
<FONT SIZE="4"><FONT COLOR="red">No! Mixing mount kits is stupid as hell. You're motor will not align properly, let alone even fit in the bay, and you're axles will wear out prematurely. Also, good luck getting a custom set of linkages to match that.</FONT></FONT>
Save your money, and order the HASports through HMotors.
might ask him if he has all necessary bolts/washers included in the auction also. he doesn't have it in the picture, and if he lost his tranny mount he more than likely lost all the hardware to go with it.
Might also ask him if anybody ever mounted an engine with these mounts. The tranny mount (the tall one) looks OK. The one in the middle apears to be the drivers' side mount but the one on the right??? I'll assume that this is the rear mount. The plate on the reat mount has to bend to follow the contour of the rear frame rail and usually bolt up with two bolts. This does not look like the rear mount, in fact I don't know where that mount would go. Personally, I would pass.
HTH
chris
HTH
chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matrix_Zero »</TD></TR><TR><TD CLASS="quote">Honda 88-91 CRX/Civic B16a/B-Series Motor Mount Kit 225+15 s/h
Modified by Matrix_Zero at 2:56 PM 8/18/2004</TD></TR></TABLE>
DUDE!! NO!! if you're on a budget, just buy some Lifetime waranty HCP mounts from JDMSHIT.com that's what i'm running on my obd-1 B18 swap into my Civic hatchback... the mounts are perfect and they sell a matching shift linkage for only 100 bux.. I just made mine.. but ya.. the mounts are only about the price of the used ones you're trying to buy!
Good luck man..!
Mark
Good luck man..!
Mark
yeah dont get those. you should wait a little till you have the money to get the hasport mounts you wont regret it.
how do you bolt up the rear tranny mout??
Rear crossmemeber ^ front of car
normal mound bolts like this...
<FONT SIZE="4">:</FONT>
______
This set bolts like this?
<FONT SIZE="4">. .</FONT>
_______
do you have to drill holes in the crossmeber to make that rear fit??
others < haport
______
_______
others < haport
doublethink
Oct 6, 2007 09:30 AM
