ls dizzi w/ mad ls/vtek y0
im running a hacked up LS distributor on myls/vtec and its throwing a code 9... im pretty sure its relating to the dizzi... will a gsr dizzi fix this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">That sensor is in the distributor. Try switching it and see if that helps.</TD></TR></TABLE>
well i replaced the distributor with another one (both LS distributors) and they both throw that same code. the car runs fine, but is kind of hard to start (sometimes stalls out, i gotta give it a little bit of gas for a second or two then it's a-ok)
I am pretty sure the timing is a little off and your car won't run as good as it can but I'm thinking there must be some other issue if you keep throwing that code. You can try to switch to a gs-r but I don't know if thats your problem. Good luck.
