Blinker is stuck on WTF??
Old Aug 17, 2004 | 09:56 PM
Edgemingsr's Avatar
Default Blinker is stuck on WTF??
When i turn my lights on at night the driver side blinker stays on. It doesnt blink it just stays on.. anyone know why? does it just need a new bulb?
Old Aug 17, 2004 | 10:20 PM
DCApex8's Avatar
Turn your lights on one notch, get out, and look at your car...See the lights under the headlights on?..Make note of it, then turn your blinker on...Its not your blinker, I don't think, just the "sides" lights.
Old Aug 17, 2004 | 10:35 PM
jaydeemmmm's Avatar
It has to be the taillights right? Your flasher unit might be defective.
Old Aug 17, 2004 | 10:53 PM
Edgemingsr's Avatar
Default Re: (jaydeemmmm)
the actual blinker is stuck on, when i drive the amber light in the tail light stays lit and the green arrow on my dash stays lit.
Old Aug 18, 2004 | 10:42 AM
Edgemingsr's Avatar
Default Re: (Edgemingsr)
anyone else?
Old Aug 18, 2004 | 11:41 AM
CalGSR99's Avatar
One of your fuses might be burnt out. Check your fuses.
Old Aug 18, 2004 | 11:45 AM
JimBlake's Avatar
Default Re: (CalGSR99)
Look in the sockets at the front. One of those bulbs is supposed to be a 2-filament bulb, it should have 2 little nubs at the base. If you stuff a single-filament bulb in there (it can be done) then the parking light circuilt will feed back into that side turnsignal circuit. Same thing happens if the 2 nubs are mashed together into one with heat & age...
rawrjaay
Aug 24, 2022 02:38 PM
OneFire
12
Jun 30, 2011 06:38 PM
CPreston
Lighting
May 21, 2009 11:35 AM
simplypinoyy
Jul 12, 2008 11:59 PM
bmxer
Feb 2, 2008 07:00 PM
