How much oil for 95 LS motor?
Old Aug 17, 2004 | 09:54 PM
silverb18's Avatar
Default How much oil for 95 LS motor?
I'm doing my first oil change for my LS motor, how much oil should I put in?
Old Aug 17, 2004 | 10:20 PM
BlackThorN's Avatar
Default Re: How much oil for 95 LS motor? (silverb18)
acura service manual says 3.7 us quarts, I'm not sure if this counts the filter, but I think I remember using somewhere above 4
always add and then check it
I'm sure someone else will jump in and help too, but the manual does say 3.7
Old Aug 17, 2004 | 10:22 PM
DCApex8's Avatar
4.5 quarts with filter replacement, 3.7 if keeping same filter.
Old Aug 17, 2004 | 10:24 PM
BlackThorN's Avatar
thanks for helping out
Old Aug 17, 2004 | 10:31 PM
orangebarius's Avatar
Default Re: (BlackThorN)
i use 4 quarts with the filter change in my 94 ls. never had a problem
Old Aug 17, 2004 | 10:32 PM
silverb18's Avatar
Ok thanks alot guys, so i'll drain everything and the filter, then fill it up to about 4, check the dipstick and see where I need to be, I want to be just below the full mark, right?
Old Aug 17, 2004 | 10:56 PM
Sack Master's Avatar
Default Re: (silverb18)
Have someone change it for you if you don't know how. If you just add 4 quarts and it looks fine. Then its probably not enough. Filter holds about .5 quarts. I'm not sure if it's the same as a gs-r but its 4.2 in the pan and 4.6 overall.
Old Aug 19, 2004 | 12:56 AM
JdmEg6Hybrid's Avatar
Default Re: (Sack Master)
i used 4 qt w/ the new oil filter
Old Aug 19, 2004 | 01:57 AM
oilchange1qt's Avatar
I showed up with 1 qt. of oil ( hence the name) and my friends laugh at me till this day...don't make same mistake...
Old Aug 19, 2004 | 01:54 PM
Default Re: How much oil for 95 LS motor? (oilchange1qt)
the ls take 3.7, so u just round up to 4 and ur good. use 4 in the ls. period.
christian7750
23
Mar 31, 2009 01:16 PM
wesk18
Dec 26, 2008 10:56 AM
Irritated_Onion
Jun 5, 2008 04:39 PM
TOO MUCH TORQUE
Mar 8, 2008 03:01 PM
Asselin
Jul 7, 2006 08:07 AM
