How much oil for 95 LS motor?
Re: How much oil for 95 LS motor? (silverb18)
acura service manual says 3.7 us quarts, I'm not sure if this counts the filter, but I think I remember using somewhere above 4
always add and then check it
I'm sure someone else will jump in and help too, but the manual does say 3.7
Re: (BlackThorN)
Ok thanks alot guys, so i'll drain everything and the filter, then fill it up to about 4, check the dipstick and see where I need to be, I want to be just below the full mark, right?
Re: (silverb18)
Have someone change it for you if you don't know how. If you just add 4 quarts and it looks fine. Then its probably not enough. Filter holds about .5 quarts. I'm not sure if it's the same as a gs-r but its 4.2 in the pan and 4.6 overall.
christian7750
23
03-31-2009 01:16 PM
