Polishing Cast Aluminum Intercooler
Old Aug 17, 2004 | 09:06 PM
Tchleung's Avatar
Default Polishing Cast Aluminum Intercooler
My IC has cast aluminum end tanks... quite rough.. How do I polish it to a shine? Do I ahve to fully send it down to smooth surface then polish? please let me know.
Old Aug 17, 2004 | 10:25 PM
tegasaurus's Avatar
Default Re: Polishing Cast Aluminum Intercooler (Tchleung)
run 400 grit sand paper over it for about 2-3 min, until everything is pretty smooth. Then go up to 600 or 800 grit sand paper (again, until smooth). Then 1000 grit finish with a 1500 wet sand.
Bust out your dremel w/ the polish wheel and start polishing with an aluminum polish (the kind supplied in the dremel polish kit works great). then you're blinging.
Old Aug 17, 2004 | 10:37 PM
Tchleung's Avatar
Ohh. so just sand out the rough surface till it's nice.. Thanks alot! (Y)
Old Aug 26, 2004 | 08:41 AM
funkfnamna's Avatar
Default Re: (Tchleung)
if you want it to shine alot you have to get the surface totally smooth. use a 3 inch sanding wheel with something around 300 to cut down the casting then just go at it with the stages...400,600,800,1500 whatever you choose
Old Aug 26, 2004 | 11:28 AM
BB6-213's Avatar
Mothers Billet Pollish works awesome, it's like 12 bucks for a little jar, but well worth it.
Koyoloeor
May 16, 2005 05:39 AM
turbo gli
Welding / Fabrication
May 11, 2005 01:10 AM
EARLdaSQUIRREL
Jul 21, 2004 08:51 PM
JDEM1
Dec 29, 2002 08:21 PM
deacs
Nov 22, 2002 07:03 AM
