DOHC ZC unused plug
Old Aug 17, 2004 | 08:45 PM
HondaKPX's Avatar
Default DOHC ZC unused plug
Is there an unused plug on the Si wiring harnes when putting in a DOHC ZC? On my d16 there is a wire that hangs down off the back of the intake manifold that plugs into the harnes that runs under the intake manifold. (sorry but i dont know what this is for so i cant be more specific) but eather way that plug isnt on my ZC. and i dont know what to do with the plug on the harness. just leave it? any help would be usefull.
Old Aug 17, 2004 | 10:02 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: DOHC ZC unused plug (HondaKPX)
u say UNDER the IM? could be for a knock sensor. :/ just my 2 cents
Old Aug 17, 2004 | 11:03 PM
Rywire's Avatar
Default Re: DOHC ZC unused plug (JC18)
I had it on my first b16a swap, dont worry about it, it was a sensor thats sometimes on the firewall, and sometimes on the IM on civics and crxs. Name escapes me right now. You dont need it on the bseries because it was only on the firewall on jdm cars. Cut it, or leave it. Its a 2 pin connector, right?
Old Aug 17, 2004 | 11:24 PM
JapJunkie's Avatar
i have the same thing(plug) on my DOHC ZC??? It hangs could be from the IM. Its in an 88 hatch STD, dont know if they used that wiring harness or any other
Its probably the same thing
Old Aug 17, 2004 | 11:39 PM
dcvt16's Avatar
Default Re: DOHC ZC unused plug (hondadict)
fast idle control valve.
Old Aug 18, 2004 | 07:58 AM
tgreaves's Avatar
I might be for the tandem valve..
Old Aug 18, 2004 | 08:32 AM
NCRXSi's Avatar
Default Re: DOHC ZC unused plug (dcvt16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcvt16 &raquo;</TD></TR><TR><TD CLASS="quote">fast idle control valve.</TD></TR></TABLE>
Not needed on the ZC.
Old Aug 18, 2004 | 01:15 PM
HondaKPX's Avatar
Default Re: DOHC ZC unused plug (NCRXSi)
thanx
Old Aug 18, 2004 | 05:49 PM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">
Not needed on the ZC.</TD></TR></TABLE>
So can i just snip mine off?
Old Aug 19, 2004 | 08:20 PM
Rywire's Avatar
fast idle control valve is right. Snip it, or just wrap in in tape. Who knows, possibly you will need to put the stocker back in.
AudioXtremes
Apr 11, 2006 01:26 AM
99sonicbluegsr
Sep 27, 2004 11:22 AM
99sonicbluegsr
Sep 16, 2004 07:43 AM
claytonsmith
Jun 8, 2004 10:53 PM
