Gas mileage on 2000 si
If you drive harsh all the time then yes it is.
Go here and figure it out.
http://autos.msn.com/research/...sub=0
depends on how you drive? for a daily driver that sounds horrible because i have a gsr motor in my civic with a 10.9 gallon tank i believe and even driving like a jackass all the time i still manage around 250 miles per tank.
if drive slow i get like 230. and if i punch it i get like 170. what can da problem be becasue of. and it cannot be because of the cluster because my car wouldnt start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT »</TD></TR><TR><TD CLASS="quote">I get 360 regularly. You might need a tuneup. </TD></TR></TABLE>
that sounds like a lot to me, how many gallons do u usuall fill up? 10-10.5?
i usually fill up and takes up about 9-10 gallons at about 270-280
I've gotten as low as 210-220, but that's really low, usually Strict City/stop-go driving or higher rpm driving (auto-x, agressive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 »</TD></TR><TR><TD CLASS="quote">yeah i didnt touch anything. i jus got new dunlop tires.</TD></TR></TABLE>
have you run a fuel injector cleaner before? couldn't hurt to try that.
Yes i fill mine up everytime from empty. I always run it until the low fuel light comes on. Keep in mind I live in WV and drive mostly 2 lane roads. I get pissed when I only get 320 on a tank. My mileage is always between 32 and 34 mpg. It depends on how i drive.
All highway miles = around... 350-400 miles to a tank.... i think i figured it for a lil over 40 MPG
City driving with a lil ****** around= is in the 260-270 range... (miles per tank)
93 ex d16z6... prob. no help but... w/e
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 »</TD></TR><TR><TD CLASS="quote">problem solved it is my plugs, and cap. what plugs should i get im thinkin NGK but should i get a stock cap???</TD></TR></TABLE>
NGK or Denso is fine. OEM cap.
How do you know it's the plugs?
casue there is no other problem i changed my oil 2 days ago, i cleaned my intake filter, i changed my fuel filter, there can be no other problem. and i was actually driving slow i got 200 miles. when i punch it and drive fast i get liek barely 180 its bullshit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 »</TD></TR><TR><TD CLASS="quote">casue there is no other problem i changed my oil 2 days ago, i cleaned my intake filter, i changed my fuel filter, there can be no other problem. and i was actually driving slow i got 200 miles. when i punch it and drive fast i get liek barely 180 its bullshit</TD></TR></TABLE>
How many miles do you have on them? I think I might need to change in my car too.
Check compression? Could be a deeper issue thats not too bad yet. I just don't see the plugs causing that dramatic of a milage loss. Hopefully I'm wrong though.
