what is the difference between a h22a tranny vs the f22
Old Aug 17, 2004 | 07:42 PM
GReddySiR's Avatar
Default what is the difference between a h22a tranny vs the f22
anyone know what the difference is between the tranny that comes with the H22a on an JDM Accord SIR vs the stock f22 tranny? how can you tell them apart? are they any code or signs? what is the difference in gear rations?
Thanks
Old Aug 17, 2004 | 07:59 PM
SKDRCR's Avatar
Default Re: what is the difference between a h22a tranny vs the f22 (GReddySiR)
4th Gen
F22/S- H23a/Si - H22a/VTEC
--M2L5----M2S4----M2F4
1 - 3.307 - 3.307 - 3.307
2 - 1.810 - 1.857 - 1.950
3 - 1.230 - 1.320 - 1.360
4 - 0.903 - 1.034 - 1.071
5 - 0.705 - 0.812 - 0.870
FD 4.062 - 4.266 - 4.266
*Above info taken from USDM Helms manual.
M2B4 (JDM LSD) M2J5 (JDM) M2A4 (JDM)
1. 3.307 1. 3.307 1. 3.307
2. 1.950 2. 1.810 2. 1.950
3. 1.360 3. 1.269 3. 1.160
4. 1.034 4. 0.966 4. 1.034
5. 0.787 5. 0.787 5. 0.787
FD 4.266 FD 4.062 FD 4.266
*Above info taken from teardown and tooth counts.
5Gen:
1st 3.285
2nd 1.956
3rd 1.344
4th 1.034
5th 0.812
FD 4.266
*Above taken from USDM Helms manual.
*above taken fron poison's post in the FAQ's*
lots of the info you will need can be found there
Old Aug 17, 2004 | 08:03 PM
GReddySiR's Avatar
Default Re: what is the difference between a h22a tranny vs the f22 (SKDRCR)
Thanks man! what about for an automatic?
Old Aug 17, 2004 | 10:39 PM
salvageland's Avatar
u guys know if they use the same housing? as in will an F22 tanny housing bolt up with an H22 tranny housing, say if I wanted to switch the internals.
Thanks
Old Aug 18, 2004 | 12:05 AM
GReddySiR's Avatar
bump
93PreludeVTEC
May 14, 2007 06:31 PM
kornerk12
Sep 22, 2006 08:39 PM
GReddySiR
Aug 19, 2004 01:33 AM
mstsh80
Feb 1, 2004 12:13 PM
2point6
Jul 29, 2003 05:44 PM
