accessory power source?
Old Aug 17, 2004 | 05:58 PM
chadmasterc's Avatar
Default accessory power source?
I am putting a alarm and a cb in my car and i was wondering which wire should i tap into for accessory power source( the one that comes on when you turn the ignition on).
Is their one going to the cigarette lighter?, if their is what color is it?
Old Aug 17, 2004 | 07:50 PM
Default Re: accessory power source? (chadmasterc)
also need the color for the ground wire for the cigarette lighter. someone hit me up im trying to get this finished tommorow.
Old Aug 17, 2004 | 08:21 PM
shawn_crx's Avatar
If your Cig lighter shut off when you turn your key off then you could use it.
Don't know the color, but I pretty sure the power wire is the wire that connect to the middle part of the cig lighter...
Old Aug 17, 2004 | 08:26 PM
EJ1 wilcox's Avatar
Here you go...
The best way to identify which is which is to test each individually...
For my car ('95 EX Coupe)
A = constant 12v
B = ?
C = ?
D = switched 12v, comes on with lights
E = 12v ignition, comes on with ignition
I hope this helps!
Old Aug 17, 2004 | 08:47 PM
riceisnicenv's Avatar
Default Re: accessory power source? (EJ1 wilcox)
my cigarette lighter gets hot if i push it in even with my car off and keys out... i wired my neons (puts on flame suit) into the leads for my radio.
Old Aug 17, 2004 | 09:05 PM
I forgot all about the optional connection points where the fuses are, i put in one of those headlight buzzers in about 2 years ago and hooked it up there. thanks man.
Old Aug 17, 2004 | 09:25 PM
Jester88Si's Avatar
If you want a power source when the ignition is flipped on and doesnt turn off when you start the car tap into the Black/yellow stripe wire in the ignition switch harness.
Old Aug 18, 2004 | 01:28 AM
SETI20's Avatar
make sure you use a nice power distribution block, and use the proper fuses.
super civic
Honda Civic (2006 - 2015)
Oct 9, 2008 07:48 AM
jerm001
Audio / Security / Video
Aug 27, 2004 06:39 PM
Hatch It
Jun 8, 2004 07:33 AM
clutch33
Sep 23, 2003 04:22 PM
