02 Sensor compatibility..EX/SI Helms Manual Check, Please
Old Aug 17, 2004 | 03:54 PM
ILLICON3000's Avatar
Default 02 Sensor compatibility..EX/SI Helms Manual Check, Please
I drive a 2000 civic EX, will a 2000 civic SI front pre cat oxygen sensor give accurate readings?
Old Aug 17, 2004 | 04:01 PM
pdiggitydogg's Avatar
yes it will work (both just 4wire o2's)
but the harness connector may be different.(there was a thread on this a little while ago)
If that becomes the case just cut the wires and connect the dead o2's end to the newer o2 sensor
Old Aug 17, 2004 | 04:14 PM
Hey thanks man, I already had to do that once cause I've got a 92-95 02 sensor on there... If I had known what to search for I would have. Thanks though for not being an *** and actually replying to my thread.
Old Aug 17, 2004 | 04:38 PM
donkiman's Avatar
Default Re: (ILLICON3000)
ya it works just make sure you plug it into the first plug and not the second one.
dohcteg
Jul 10, 2007 11:56 AM
Sinner
Jan 9, 2004 06:11 PM
Loveless
May 26, 2003 01:39 AM
