Time for a timing belt
Old Aug 17, 2004 | 03:03 PM
gsrboi80's Avatar
Default Time for a timing belt
Quick ? When doing a timing belt I know I should change the water pump but is it also nesesary to change the tensioner
Old Aug 17, 2004 | 03:06 PM
jdmteg01's Avatar
Default Re: Time for a timing belt (gsrboi80)
might as well you are already in there
Old Aug 17, 2004 | 03:07 PM
gsrboi80's Avatar
Default Re: Time for a timing belt (jdmteg01)
Did all u guys change it too
Old Aug 17, 2004 | 03:12 PM
DriveSideWays's Avatar
yup u should. its only easier to once u've taken it off and its probably due changing
Old Aug 17, 2004 | 03:23 PM
hond77's Avatar
Default Re: (DriveSideWays)
Its always good to replace other parts while you are going to do some maintenance work.
Old Aug 17, 2004 | 04:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrboi80 &raquo;</TD></TR><TR><TD CLASS="quote">Quick ? When doing a timing belt I know I should change the water pump but is it also nesesary to change the tensioner</TD></TR></TABLE>
I am at 174K miles and am about to install the car's 3rd timing belt. I am still on my original water pump and tensioner pulley, and have not had problems with either one yet, but I do have a new water pump and tensioner pulley ready to install along w/ the new belt.
Old Aug 17, 2004 | 05:41 PM
boosted k20's Avatar
definitly get the water pump. im do n mine next week along with cam install. but im not gonna change the tensioner
Old Aug 17, 2004 | 05:48 PM
Brian_TII's Avatar
I did the tensioner. It's not THAT expensive and you have to deal with it all anyway. Better safe than sorry on that stuff... it'd really suck to replace the belt and then have the water pump or tensioner seize up and tear up the belt (and motor).
Old Aug 17, 2004 | 08:08 PM
Community Builder
Default Re: Time for a timing belt (Brian_TII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian_TII &raquo;</TD></TR><TR><TD CLASS="quote">I did the tensioner. It's not THAT expensive and you have to deal with it all anyway. Better safe than sorry on that stuff... it'd really suck to replace the belt and then have the water pump or tensioner seize up and tear up the belt (and motor).</TD></TR></TABLE>
Well the tensioner does run about $50-$60, and Honda does not list it as an actual maintenance item. I would say at the 2nd timing belt change you might want to do it (180K) but at the first one it's probably not necessary.
Old Aug 18, 2004 | 10:23 PM
GoHonda91's Avatar
nah u dont need to replace the tensioner
Old Aug 18, 2004 | 10:36 PM
00siALLmotor's Avatar
Yea, I would change the tensioner... While you're at it...Do a MAJOR tune up as well... (spark plugs, wires, dist cap, rotor, motor oil & tranny fluid, valve adjustment...ect... Helps a lot and in my opinion, makes a HUGE difference... Good luck...
hondahenry
Jul 19, 2015 02:36 AM
petrv
May 10, 2006 03:24 AM
lv6l
10
Oct 13, 2005 07:27 AM
zracer240
Aug 1, 2005 10:07 AM
1998hondaaccord
Sep 18, 2003 07:25 AM
