Need help 1999 EXV6 CEL
Old Aug 17, 2004 | 01:18 PM
1999gs-r's Avatar
Default Need help 1999 EXV6 CEL
The check engine light came on in my 1999 EXV6. I took it to Auto zone and they retrieved the codes.
P0401=The PCM has determined that there is insufficient flow in the exhaust recirculation system. (This one was in there twice)
P0420=The PCM has determined that the catalyst system efficiency for bank 1 is below threshold for the current engine operating conditions. (Bank 1 identifies the location of cylinder #1, While bank 2 identifies the cylinders on the opposite bank)
I think the first one is talking about the EGR valve but what is the second one talking about? Any help would be greatly appreciated.
Old Aug 17, 2004 | 01:58 PM
bill-71SS's Avatar
Default Re: Need help 1999 EXV6 CEL (1999gs-r)
the 401 code is the egr ports are clogged,the 420 means you need a new cat. converter. Now both items carry a 80,000 mile extended warranty by honda,so if you have 80 or less it is free,if not it gets costly.
Old Aug 17, 2004 | 02:11 PM
1999gs-r's Avatar
Default Re: Need help 1999 EXV6 CEL (bill-71SS)
Does anyone have a picture of or can explain where the EGR valve is?
Old Aug 17, 2004 | 02:46 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999gs-r &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have a picture of or can explain where the EGR valve is?</TD></TR></TABLE>
P0401 is more likely a clogged EGR passage than a bad EGR valve. How many miles do you have on it?
Old Aug 17, 2004 | 02:55 PM
1999gs-r's Avatar
Default Re: Need help 1999 EXV6 CEL (Chiovnidca)
88,648 miles. I found the EGR valve. I don't see any hoses coming out of it. To clean the ports would I unbolt it and clean underneath?
Old Aug 17, 2004 | 03:17 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999gs-r &raquo;</TD></TR><TR><TD CLASS="quote">88,648 miles. I found the EGR valve. I don't see any hoses coming out of it. To clean the ports would I unbolt it and clean underneath?</TD></TR></TABLE>
Nope, the intake manifold has to come off. The port clogs up in it.
Old Aug 17, 2004 | 03:37 PM
1999gs-r's Avatar
It doesn't look like it is bolted to the IM. It looks like it bolts to the water pump. Up front. Just to remind you this is a V6 accord. go to http://www.hondaautomotivepart...V6%29
Old Aug 17, 2004 | 05:14 PM
bill-71SS's Avatar
you have to remove the plenum [intake] and clean out the blocked up port on the underside
ifIexplode
Jul 9, 2006 08:29 PM
imjac1
Mar 5, 2005 07:22 PM
mikester_91
Jan 11, 2005 05:20 AM
bpowa
Oct 12, 2004 04:39 PM
turbolag98
Nov 15, 2003 08:10 AM
