About my tranny
yes there is... but if you dont know, i wouldn't recommend cracking a tranny case. heres an easy fix thats temporary: check the oil in the trans... if its low, drain it and fill it to spec. use 10w-30 motor oil or honda mtf. you can also try gm syncromesh (dont get friction modified, its for LSD's). if that doesn't help it, rebuilds are more expensive then finding a junkyard tranny (like a jdm import). those are a bit cheaper, not gauranteed to be grind free... but they're low mileage, so they probably are.
if you really want info on how to replace what needs to be replaced in a tranny to stop grinds... do a search and if you find nothing, reply and i can give you a general idea.
sL3epy187
Transmission & Drivetrain
Sep 4, 2008 09:38 AM
HondaHeddie
16
Sep 29, 2006 07:40 PM
