JDM D15B swap questions (Intake manifold)
Old Aug 17, 2004 | 10:04 AM
spyderracing's Avatar
Default JDM D15B swap questions (Intake manifold)
Ok, so I'm on the VERY last leg of my swap.... reconnecting hoses, and electrical clips. I have most of them all on, but I have a few hoses and clips left that should go on the intake manifold. I looked at my VX manifold, and I can see where they go, but those spots do not exist on the JDM D15B manifold. What do I do about this? Will it run right with these disconnected on the p08 ecu? Don't wanna have to replace the intake manifold again ....
Old Aug 17, 2004 | 10:47 AM
Default Re: JDM D15B swap questions (spyderracing32)
bump
Old Aug 17, 2004 | 12:29 PM
up up up come on fellas
Old Aug 17, 2004 | 01:06 PM
come on ppl.... the vehicle is a 93 VX
Old Aug 17, 2004 | 01:35 PM
Old Aug 17, 2004 | 09:49 PM
NineTwoSi's Avatar
Get a d16z6 mani. it will have all the appropriate connections for you to hook everything up right... You can make the d15b one work by T'ing of some of the vacuum lines but that's kinda ghetto IMO...
Old Aug 18, 2004 | 06:40 AM
Default Re: JDM D15B swap questions (I Am Jack)
Well the extra hoses are the EGR valve hoses (VX only), so I just took em out. Thanks for the input all (search pwns me )
Old Aug 18, 2004 | 06:52 AM
hondapwr's Avatar
What the heck is a D15B and why would you want it?
Old Aug 18, 2004 | 07:02 AM
Slammd Sol's Avatar
One sensor that wont be used on your D15b is the EVAP sensor. It goes on the back of the intake manifold, by the brake booster.
you can refer to this thread for some more info:
http://www.hondavision.com/for...47268
Old Aug 25, 2004 | 08:07 AM
hondapwr's Avatar
Default Re: JDM D15B swap questions (hondapwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr &raquo;</TD></TR><TR><TD CLASS="quote">What the heck is a D15B and why would you want it?</TD></TR></TABLE>
I found the info from hybrid-garage. It's a 130HP 1.5Liter... Still not sure why anyone would want it though.
Old Aug 25, 2004 | 09:09 AM
NineTwoSi's Avatar
because it's a good single cam vtec motor... good alternative to a z6 if you can't afford b-series or if a b isn't your cup of tea.
Old Aug 26, 2004 | 12:40 AM
jdmsiR20's Avatar
i tee'd off my purge cut solenoid valve...
other than that, i have no idea where the EGR hooks up. i've only done d15b swaps on cx's/dx's
Noobster425
Apr 13, 2010 06:33 PM
4d00rEF
Mar 28, 2010 11:43 AM
R_type
Jun 1, 2005 04:26 AM
Triumphant
Dec 11, 2003 09:45 AM
