exhaust over left (driverside) rear LCA?
anyone try custom piping over the left lca instead of the right lca? or even straight back?
i looked at it just now and there's just as much room over the left lca as the right lca. if i can run a can style muff on the left...1. i wont have a low hanging muff, 2. i would have maximized flow, 3. it would still be on the left to match the bumper. only problem is that there is that the gas tank fill up pipe is there. i dont want to heat it up and cause a problem.
Yes, I have a friend who had an exhaust made on his 2nd gen integra(similar exhaust set up as yours) and he had it rerouted to the driverside and under the control arm. No problems at all.
I did the same thing on my crx i went under the control arm and i have had no problems with it hitting the control arm or scraping on the ground
*ctrlaltdel
Aug 3, 2009 12:39 PM
JBirch_97Prelude
Jan 3, 2009 04:26 AM
